Old 10-02-2010, 10:28 AM   #1
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Question for all you computer people?
Hey, I'm thinking about building a new computer and right now I'm hung up on what case to get. I don't want water cooling, but I would like to get a case that keeps the internal temps way down but doesn't look like its from another planet.
Depending if I get hung up on more components I'll probably keep this thread running.
Thanks in advance!
EDIT: A couple questions as well...
Are there any benefits to go to a smaller or larger case for cooling? What about materials? Some are aluminum, steel, etc?
Kyle2k is offline   Reply With Quote
Old 10-02-2010, 10:57 AM   #2
Epitaph
Custom User Title
Drives: Fast
That depends. Are you building a gaming rig? How many video cards are you going to put it in? What size are they?
The Antec cases are some of the best designed cases out there, and they're pretty cheap (not cheaply made).
If you want a basic look, and assuming everything fits, go with the Antec Three Hundred.
My bro-in-law bought a Cooler Master & it works flawlessly. No excess noise from fans. I would recommend them as well.
http://www.newegg.com/Product/Produc...NG&PageSize=20
FYI - it's never a bad idea to buy an extra fan or two if you're worried about overheating. I don't how many spots there are for fans on the 300, but it includes a 120mm & 140mm(one on top, the other on the back, you can add a 3rd on the side). Even if you do overclock, it should be more than enough to cool.
Epitaph is offline   Reply With Quote
Old 10-02-2010, 11:02 AM   #3
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
It's going to be a budget gaming rig for now. Going to just pull my 3870 that I have now, but get a decent processor and overclock it. Maybe a solid state hard drive? Don't know if that is worth it or not.
Old 10-02-2010, 11:05 AM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
http://www.tomshardware.com/reviews/...fans,1203.html
next question.
I piss excellence
and fart awesomeness
Old 10-02-2010, 11:14 AM   #5
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Originally Posted by CamaroSpike23 View Post
lol...ugh Greg
Old 10-02-2010, 11:42 AM   #6
CamaroSpike23
Truth Enforcer
Originally Posted by Kyle2k View Post
lol...ugh Greg
you asked...lol
I piss excellence
Old 10-02-2010, 12:44 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
http://www.newegg.com/Product/Produc...-065-_-Product
140mm fan on top, 120mm fan on the back, 120mm fan on the side, two 120mm fans on the front, and the power supply fan.
This is the case I use for my gaming computer.
- X
P.S. - To answer your question, smaller cases are better than larger cases for cooling. Less airflow is required, and air can't absorb heat readily enough to make a larger case viable (unless its filled with oil). I've never personally found case material to make a difference.
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 10-02-2010, 12:54 PM   #8
CamaroSpike23
Truth Enforcer
lol...ugh Greg
and dont you have better places to spend that money.... *cough*ITB's*cough*
I piss excellence
Old 10-02-2010, 12:55 PM   #9
Xanthos
PWA Relapse
Xanthos's Avatar
I'd love ITBs on my LT1. Just saying.
- X
Old 10-02-2010, 01:00 PM   #10
CamaroSpike23
Truth Enforcer
usually true, as long as the airflow is free flowing. if its crowded and the air has to turn and jut back to get out, it doesnt carry the heat out as efficiently.
kinda like a CAI.... remove the restrictions and it will perform better.
I piss excellence
Old 10-02-2010, 01:04 PM   #11
Xanthos
PWA Relapse
Xanthos's Avatar
Agreed, but I find that the airflow can be setup to flow nicely by adjusting fan speeds. A low speed here, a high speed there... All add up to a nice, smooth air path through the case.
- X
Old 10-02-2010, 01:07 PM   #12
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Any opinions on the solid state hard drive?
Old 10-02-2010, 01:10 PM   #13
Xanthos
PWA Relapse
Xanthos's Avatar
I have both a solid state (in my laptop) and standard 7200 rpm drives in my striped raid. The diffence in speed is there, but in my opinion its not worth the extra cost.
- X
Old 10-02-2010, 01:44 PM   #14
CamaroSpike23
Truth Enforcer
- X
kinda like speed zones on a video game... lol regular speed here, a little boost there...lol
I used to have a setup that had a single, six blade, 30" fan on the side that spun at a moderate speed and an open air filter element on the other side to keep it clean. then I overclocked it and fried the motherboard and sold the case.
see below...
- X
currently not worth the cost. but look back a few years at the cost of larger HDD's. give it a little time and the prices will come down.
with a SSD, you dont have mechanical arms and spinning platters that are most easily damaged in HDDs.
That being said, SSD's are more apt for usage in notebooks/laptops and such that are constantly being moved around, bumped, sometimes dropped, etc.
HDDs work just fine in a desktop computer where the case is not being shuffled around on a regular basis.
SSD's also consume less power than HDDs based off of the nature of how they operate. they dont have any moving parts to draw energy to move. adding into that, SSDs dont build up the heat that HDDs do as well.
SSDs are also faster than HDDs. but, as Xan said, they are pricier compared to HDDs, and another thing that just popped in my mind is that when you delete something from an SSD, it is gone. it wont do like a traditional HDD and "soft delete" it and just rename the file and store it elsewhere.
what you can do is find a compromise. run a 60Gb SSD for your primary drive and run a larger HDD as your secondary storage. This way you can get the effects of the SSD's speed and still afford the larger storage space at an affordable cost with the HDD.
I piss excellence
ONE MORE QUESTION PEOPLE!!!! fireresq157 5th Gen Camaro SS LS LT General Discussions 0 06-24-2009 03:40 PM
NEW!! Voice Your MARKETING Suggestions/Input for Focus Group on 2010 Camaro. Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 114 05-08-2008 09:24 PM
Hey Tag! Have you been trained to draw blood yet? Silverado Off-topic Discussions 16 12-30-2007 09:00 PM
Question for people who have turboed muscle cars Mindz General Automotive + Other Cars Discussion 14 10-15-2007 06:45 AM
