dave@hennessey
Old 10-01-2010, 12:06 PM   #1
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
1SS MPG tips
Hey guys, my 1SS has been averaging only 13.5 MPG. It's an M6 and while I know it's pretty much nothing but city driving, I'm sure I can get it up to at least 15 or 16 MPG. Any tips? Keep in mind, I'm new to stick and am just starting to get the hang of it. How do I drive stick the most efficiently?
P.S. I'll have pics up soon! The weather here in FL has been terrible and I haven't even washed the poor girl since I got her last Thursday! I feel bad. :P
nUcLeArEnVoY is offline   Reply With Quote
Old 10-01-2010, 12:08 PM   #2
c-dub
It's that guy
c-dub's Avatar
Drives: 2011 SIM SS/RS
keep the RPM's as low as you can. I have primarily city/town driving also and I just keep the RPM's as low as possible and I'm averaging 16.5-ish.
c-dub is offline   Reply With Quote
Old 10-01-2010, 12:09 PM   #3
c-dub
It's that guy
c-dub's Avatar
that was just my $.02 I'm pretty new to stick shift also.
Old 10-01-2010, 12:11 PM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
The only tip would be, the lower you keep the RPM the better your mileage will be. Myself most of my driving is around town with 45Mph limits. I drive it basically like a 4 speed and get around 14.5 out of it. I didn't buy the car for the Mpg, when it needs gas it just gives me another excuse to drive it ...
SlingShot is offline   Reply With Quote
Old 10-01-2010, 12:16 PM   #5
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Yea, short shift her. By that I mean keep the RPMs below 2k. Oh, and keep your foot out of her, if you can........muwaaaahaaaaaaa.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 10-01-2010, 12:36 PM   #6
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
I get around 16-18 with a supercharger...so you know I dont take it easy on the gas
But then again I do 60% highway and 40% city..so I guess it might be the highway factor
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 10-01-2010, 01:15 PM   #7
destroyerofu2
xbox360 tag
destroyerofu2's Avatar
Drives: 2010 inferno orange 2SS
Skip shift it and keep Rome low
Do like the car tells you
1st to 4th to 6th
That's what I do city (when there are cops around)
He he he he
Originally Posted by babytiger
And like destoryerofu2 said, WOT should be a moment of silence...
It's mine, like it or not. http://www.camaro5.com/forums/showthread.php?t=108079
destroyerofu2 is offline   Reply With Quote
Old 10-01-2010, 03:13 PM   #8
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Raise your tire pressure to 38 front 37 rear. Picked up 1.5 miles per gallon.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 10-01-2010, 03:18 PM   #9
Albion
Albion's Avatar
Drives: IOM 1ss
Same MPG issues as you,one sure fire way is cruise control,that negates a leaden foot somewhat.No good in town though,of course.Mind you, i dont have an exhaust div' to worry about MPG.
Albion is offline   Reply With Quote
Old 10-01-2010, 03:25 PM   #10
tyler20c
tyler20c's Avatar
Drives: Black 2010 Camaro SS/RS
get a tune! I went from getting 220 miles per tank to about 280+.
tyler20c is offline   Reply With Quote
Old 10-01-2010, 03:43 PM   #11
VTXrider
VTXrider's Avatar
Drives: 2010 RY 2SS/RS
When you are at speed keep it in the highest gear that won't lug the engine. This is not a v6 or i4 so you can get the RPMs really loa and still keep the engine happy.
When accelerating you will actually waste gas if you are in to high a gear, better to downshift get to the speed you want to go and then shift back to the high gear.
I know how traffic is in southern dade so I hear you. my gears when maintaining speed are as follows, none of these speeds lug the engine when maintaining speed on flat ground:
1st 0-10
2nd 10-16
3rd 16-23
4th 23-34
5th 34-48
6th >48
or sometimes
1st 0-16
2nd skip
3rd 16-35
4th skip
5th 35-50
6th >50
These gears are generally to high for any real acceleration although you could creep up on the speed. basically I drive like this 60% of the time and then burn up all the gas I saved the rest of the time by shifting between 4500 and 6000
VTXrider is offline   Reply With Quote
Old 10-01-2010, 04:10 PM   #12
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Two big things you can do
1. Shift early. Keep the RPM's as low as possible. Under light loads, the V8 has enough torque to run around town as low as 1000 RPM.
2. Go easy on the brakes. If you see a red light or stop sign coming, let off the gas before you are right on top of it, and let it coast down a little bit. (Anytime you step on the brake pedal, you are dissipating energy as waste heat).
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 10-01-2010, 04:16 PM   #13
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
Originally Posted by VTXrider View Post
1st 0-10
2nd 10-16
3rd 16-23
4th 23-34
5th 34-48
6th >48
Pretty much this. I've been able to get around 20 on average.
1st 0-12
2nd 12-17
3rd 18-25
4th 26-30
5th 31-45
6th 45+
I don't know if this keeps it exactly at 1000 RPM, but this will prevent the car from going below that which (personally) feels like when it starts to lug.
TommyTSquared is offline   Reply With Quote
Old 10-01-2010, 04:19 PM   #14
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Just don't go over 2k RPM, and you'll get this
Also have the LS3
GEEo is offline   Reply With Quote
Possible to add Homelink / Auto Dimming Mirror to 1SS shiftz33 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 113 11-06-2014 11:12 PM
MPG readout having dropped while vehicle is off? jackka 5th Gen Camaro SS LS LT General Discussions 8 08-24-2010 08:15 PM
Purchased Camaro 1SS Today - Great Dealer Experience Autofind 5th Gen Camaro SS LS LT General Discussions 33 12-31-2009 08:13 AM
Help Me Pick An Economy Car Marosolid Off-topic Discussions 75 07-11-2009 06:41 AM
