Roto-Fab
Old 08-23-2010, 05:34 PM   #1
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
Stop the Drone - Helmholtz Style
If you don't like the 1800 to 2000 RPM drone, here is a method that stops it without buying a whole new exhaust system. IT WORKS!
Here are the calculations:
http://www.camaro5.com/forums/attach...1&d=1297738549
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 08-23-2010, 05:39 PM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Looks like the V6 fix
Iwantone2 is offline   Reply With Quote
Old 08-23-2010, 05:39 PM   #3
orange-prince
QATAR 2022
orange-prince's Avatar
Drives: black cts-V coupe a6
what the hell is this !!!
orange-prince is offline   Reply With Quote
Old 08-23-2010, 05:39 PM   #4
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Wat.
Is the end of that U shaped pipe capped, or is it basically a "hidden" exhaust outlet?
Old 08-23-2010, 05:48 PM   #5
Roger Ramjet
Motor Head
Drives: CTS-V
It is similar to the V6 fix but shorter. And, the pipe is capped.
Old 08-23-2010, 06:21 PM   #6
omegaman
omegaman's Avatar
Drives: very poorly
Send a message via AIM to omegaman
cool fix. A secondary resonator 'kill' tube. where the drone goes to die.
2013 Camaro ZL1, Crystal Red, Auto, Exposed Carbon Fiber, Navigation.
omegaman is offline   Reply With Quote
Old 08-23-2010, 06:22 PM   #7
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Old 08-23-2010, 06:25 PM   #8
2010 SSRS
2010 SSRS's Avatar
Drives: 3 V8 Camaros
cool
Old 08-23-2010, 06:47 PM   #9
BigRed585Lbs
Drives: Sierra and Tahoe
Congratulations, Roger, for thinking outside the box!
It worked before, and will work, again.
BigRed585Lbs is offline   Reply With Quote
Old 08-23-2010, 06:49 PM   #10
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Yeah it works! The GM Engineers designed the stock mufflers with a Helmholtz chamber! You just reinvented the stock 2010 Camaro V8 Muffler! See cutaway pic below.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 08-23-2010, 06:54 PM   #11
mikey8
mikey8's Avatar
Drives: 2019 SS 1LE
I believe Solo uses these on some G8 applications.
mikey8 is offline   Reply With Quote
Old 08-23-2010, 06:55 PM   #12
Hicompression
Rumbly Bumble Bee
I believe GM does too.
-OBX Longtubes FTW!
Old 08-23-2010, 06:58 PM   #13
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
This is going to be the next big exhaust mod on this site.
That's the L99 muffler, right?
Old 08-23-2010, 07:07 PM   #14
toehead93
Drives: 2014 2SS/1LE
You're kidding, right? Why waste the time, effort, and money when you can pick up stock L99 mufflers for next to nothing. IMO, the better, cheaper, and more efficient way is to simply add an $85 mufflered x-pipe to replace the H-pipe. It will help reduce drone when coupled with rear mufflers and you won't lose flow like you will with the u-bend.
Congrats to the OP on the craftsmanship, it looks like you did a good job.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Me vs 05 style gt 7CAMARO7 Chevy Camaro vs... 4 07-11-2009 03:31 AM
Congress Should Stop Giving GM Funds Supermans General Automotive + Other Cars Discussion 29 03-13-2009 10:07 AM
JUST STOP camarofanatic 5th Gen Camaro SS LS LT General Discussions 33 01-10-2009 07:16 PM
Stop Bitching. . . franknbeans 5th Gen Camaro SS LS LT General Discussions 108 10-30-2008 02:01 AM
Stripe Style jack24 Cosmetics and Lighting Modification Discussions 5 10-19-2008 09:41 PM
