Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 11-30-2014, 02:04 AM   #57
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
not the best of days
I had signed up for another 2 day HPDE weekend in Oct. on the last session of the day while passing a Mustang on the back straight, the car "coughed" and then nothing. I pulled off of the track and waited for the session to end and for the tow vehicle to show up. (I was SO glad that I installed the tow points some time ago).
I had adjusted the shift light so that I would be shifting between 5000 to 5500 all day and there was nothing stupid/unlucky like a 3rd to 2nd money shift.
a picture of loading up at the track and then dropping in front of the house.............I was so bummed and dejected that I already pulled off the number tape from the doors
Old 11-30-2014, 02:28 AM   #58
h018871
Geoff
h018871's Avatar
Tear down
tore it down..........the failure was a broken chain, valves are bent and the pistons got dinged up.
the cam was worn, but not part of the problem, the cam bearings looked ok, not great, but not bad enough to cause the cam to seize.
discussion here: http://www.camaro5.com/forums/showthread.php?t=382495
Old 11-30-2014, 03:58 AM   #59
h018871
Geoff
h018871's Avatar
rebuild
getting parts for the rebuild
http://www.camaro5.com/forums/showthread.php?t=386392
Old 01-11-2015, 04:10 PM   #60
h018871
Geoff
h018871's Avatar
Engine Assembly
pictures of the assembly
Old 01-11-2015, 04:17 PM   #61
h018871
Geoff
h018871's Avatar
engine dyno results
608hp/587lb-ft
this will be a fun DD and weekend track car. meets the targets
Old 01-14-2015, 05:15 PM   #62
1fast1le
1LE.SS
1fast1le's Avatar
Drives: '13 2ss/1LE
Originally Posted by h018871 View Post
608hp/587lb-ft
Holy crap! is this rear wheel or engine hp, either way the car is going to be a hoot to drive!! By the way enjoyed your "novel", it's what being a true car lover is all about!
1fast1le is offline   Reply With Quote
Old 01-14-2015, 08:28 PM   #63
h018871
Geoff
h018871's Avatar
thx a bunch 1fast1le
it is the engine dyno sheet. I've been breaking in the clutch an can't do a full throttle pull on the chassis dyno for a bit.
just running around at part throttle it is a blast!
Old 02-03-2015, 10:11 AM   #64
h018871
Geoff
h018871's Avatar
front radius arm bushing inserts
installed the radius arm inserts and learned that the 1LE comes from the factory with inserts. they are smaller and made from the same (or similar) rubber as the bushing.
http://www.camaro5.com/forums/showth...=1#post8209927
Old 02-03-2015, 10:15 AM   #65
h018871
Geoff
h018871's Avatar
Camber Plates
in an effort to make the tires last a bit longer on the front, not have so much outside edge wear, I installed a set of camber plates.
they went on easy (the second one was easier than the first) and should allow me to go to max camber for track days and keep the street alignment most of the time. all without having to go to the alignment shop every time.
saving money is the goal, strange for a car mod!
Old 03-01-2015, 11:52 AM   #66
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
Did you build this stroker or is this at the shop?
L99CAMA2011 is offline   Reply With Quote
Old 03-01-2015, 03:54 PM   #67
h018871
Geoff
h018871's Avatar
I had the motor built, then we put it in the car.
Old 03-01-2015, 04:06 PM   #68
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Looking good man.
I need to put my Moreno plates in too...
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
Old 03-01-2015, 04:25 PM   #69
h018871
Geoff
h018871's Avatar
Originally Posted by Firefighter View Post
Looking good man.
thx
they were easy to install and a breeze to make adjustments at the track. turn in improved and the tire wear was not all concentrated on the outside edge. highly recommended for any DD that sees some track duty
Old 03-01-2015, 04:27 PM   #70
Firefighter
thx
Sounds exactly like what I bought them for.
1le, 2ss, build, h018871
