09-22-2016, 10:07 PM | #15 |
Bump in the night
Drives: '84 Monte Carlo SS, '15 Optima Join Date: Oct 2015
So when your speed data is sold to insurance companies and it shows that a driver habitually drives 3-5 mph over the speed limit what happens to your rate? It's safer to not impede traffic and drive a little faster on the interstate, is that taken into account? How is the speed data differentiated from normal driving vs. a track day? Even if you always drive the speed limit, on a challenging road it will register as aggressive driving. If you spin the tires a little on a road that has traction gravel still present after the snow has melted it will register as tire slippage and imprudent driving.
My Kia UVO system registers some of these events. It shows on my monthly driving score as a detractor from a perfect score of 100.
09-23-2016, 07:20 AM | #16 |
Drives: chevy trax Join Date: Sep 2016
Nah, I've raced a few horses (the four-legged kind) back in my glory days (I'm 63), but no illegal street racing.
** Just wanted to ask - does the module actually say 'Onstar'? How do you know it's the correct module? Thanks. |
09-23-2016, 08:26 AM | #17 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
The OnStar module is made by lg, but the give away is it will have the imei number displayed which tells us it has a cell radio in it.
09-23-2016, 08:34 AM | #18 |
Okay, thanks. Have been scouring YouTube for info about the location of OnStar module and it seems the most likely location is behind the radio or glovebox, but those vids were a couple of years old. It's raining today so will have to wait til tomorrow to investigate more.
Thanks again. Really appreciate the help. |
09-24-2016, 10:39 PM | #19 |
Next up is killing the wifi without losing anything else. (it's the black box adjacent to the onstar unit).
Lots of connectors going into that little black module. Makes me think it does more than just connect wifi. |
10-06-2016, 08:45 AM | #20 | |
Drives: '17 2SS 50th Join Date: Sep 2016
The PCB you are removing is what we call a NAD board, short for Network Access Device.
Think of it as a modem with a GPS chipset on it, while the other board is the computer. Removing it will not trigger any CEL, but it will record a DTC within the OnStar module. Quote:
I understand why some will want this off of their vehicle. You'd be surprised what this module is capable of.
'17 2SS 50th Anniversary | M6 | MRC | NPP | Nav | Sunroof | Black bowtie | GM dark tail
10-06-2016, 08:50 AM | #21 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
I'm not of the tin foil hat crowd, but that right there just irks me because I know exactly what you're saying.
OnStar should be an option. The entire system should be an option. If you want it, great, you get it and you pay for it. If you don't want it, the car is built without this module and the entire OnStar system. |
10-06-2016, 05:22 PM | #22 |
I'm less concerned about what it can do and more concerned about what anyone bored enough can do to it. It's been done before with such an utterly shameful display of "security" and then quietly fixed over the course of 5 years. For something I dont want anyway... no.
Just note: disable your wifi through the onstar app before doing this. Or you'll need to remove it the hardware way. Apparently even when connected to the car's wifi, all commands come from the onstar server rather than a direct app connection. |
10-06-2016, 08:27 PM | #23 |
Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
Has anyone confirmed that the factory Nav is disabled if you pull the radio board?
10-06-2016, 08:58 PM | #24 |
I guess I just don't see the benefit for all that work.
10-06-2016, 10:47 PM | #25 |
Sometimes it takes some effort on the consumer's end to ensure lax corporate effort in the products you're using can't hurt you. Whether it's by installing open source firmware on your wifi router because netgear's has 3+ backdoors on the stock and no immediate plans to update or if you have to pull the radio board out of your onstar unit because GM doesn't give you an on/off switch for it. Considering one of the later hacks on cars was through a dealer backdoor in the wifi being completely accessible to anyone with access to the dealer software and a laptop so they could just walk by, reset the fob to generic and drive the car away in minutes ... and that's just one of a dozen stories in the past couple years. Being in control over your car's connectivity is your right. |
06-26-2017, 08:59 PM | #26 |
Drives: Duramax Join Date: May 2017
07-28-2017, 11:36 AM | #27 |
Drives: 1973 z28 Rs, 2018 SS 1LE Join Date: Jun 2017
So just pulling the OnStar fuse is not enough to disable its ability to track and record GPS info?
2018 HBM SS 1LE Built 7/26: Black emblems, Smoked reflectors/lights, Dimple magnetic drain plugs, Carbon rock guards, Carbon fuel door, Elite Engineering Catch-can, BMR strut-brace,
07-28-2017, 12:10 PM | #28 | |
Drives: 2017 ZL1 Join Date: Oct 2016
Someone should pull the antenna and see if it damages the board. Not all radios willl be damaged if its disconnected, it depends on how lazy or constrained the engineers were - some rasios will sense this. Also its extremely unlikely the radio will work without the antenna, especially given its location behind the metal panels of the car/by wires/near metal enclosures, etc.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
