Old 08-10-2017, 11:06 AM   #15
Burly
Burly's Avatar
What is the proper torque specifications for these bolts?
Burly is offline   Reply With Quote
Old 08-10-2017, 12:42 PM   #16
PushLifeSSlim
PushLifeSSlim's Avatar
Drives: 16' 2SS NPP A8 Garnet Red
I've been experiencing a loud clicking noise near the rear passenger wheel. Just received a call this morning from the tech stating that the issue is the axle bolts. I am at just below 13K miles. They have to order the parts so I'll be picking up a rental today. I'll post when I pick it up and get more details.
Garnet Red 2SS NPP A8
PushLifeSSlim is offline   Reply With Quote
Old 08-10-2017, 01:05 PM   #17
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
^^Can you please try to provide a part number for the bolt set? Maybe ask your service advisor if its not on the receipt?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 08-14-2017, 01:43 PM   #18
PushLifeSSlim
Will do. Still waiting to hear back from the service department. Today will make 3 1/2 days that they've had my car, given Saturday was a half-day for their service department. Hoping to hear something soon.
Old 08-14-2017, 01:48 PM   #19
Sub
Sub's Avatar
Drives: 2017 ZL1
Please ask the torque value too on the half shafts!
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 08-14-2017, 04:59 PM   #20
TedJS
Drives: 2016 Camaro SS
37 lb. ft. on the initial install + 45 degrees on the final pass. Bolts must be replaced anytime they are removed.
TedJS is offline   Reply With Quote
Old 08-14-2017, 09:27 PM   #21
black96lt1
Drives: 1996 z28
I finally have my car back after almost a month and it now has a vibration/shudder at part throttle in 8th on the highway. If you give it enough gas to downshift no vibration, and the steering wheel is slightly off center. They did the transmission line recall as well, which is what took so long waiting on the parts. So I guess it will be going back in this week.
black96lt1 is offline   Reply With Quote
Old 08-16-2017, 07:53 AM   #22
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Regardless of any issues, axle bolts on a car like this are something that I would recommend checking at each oil change...if the bolts are backing out, you can most likely catch it then. I checked mine at 1000 miles, and they are all good.
How exactly did you check yours to confirm they were OK? I'm assuming you used a torque wrench set to some value, attempted to tighten, and saw no movement of the bolt, but just wanted to be sure.
I'm wondering if this is cheap insurance to just buy the new parts and perform this fix to avoid catastrophic failure and unexpected down time.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 08-16-2017, 09:38 AM   #23
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
So will the dealer install longer bolts under warranty only if the current set is failing? Can it be done as preventative maintenance?
WhiteNight is offline   Reply With Quote
Old 08-16-2017, 09:52 AM   #24
jaysonstuart
jaysonstuart's Avatar
There is also the possibility that Billy Bob factory worker was having a bad day and just didn't do his job.
jaysonstuart is offline   Reply With Quote
Old 08-16-2017, 10:40 AM   #25
vtirocz
vtirocz's Avatar
It looks like they changed the design though. So they must have investigated this far enough to determine a weakness in the production design.
I am seriously considering just buying the improved hardware and performing the fix myself.
Does this issue apply to both the hub AND axle side, or just the axle side?
Old 08-16-2017, 10:52 AM   #26
reeper
reeper's Avatar
Drives: 2010 HD D/A, 2015 Z06, 2016 2SS
Glad I ran across this. My car was going to the dealer for the transmission line recall so I called and he's now going to do the TSB as well.
They should really make this a recall....
2016 Hyper Blue A8 2SS
GM Bodykit: Black
MRR 017 wheels: Black
OEM Blackout tail-lamps
OEM SEMA Grille
35% window tint
Black glow-tie
BMR Suspension (Pretty much everything)
ACS rear-deck spoiler
Rotofab CAI
Lolly-pop red rotors by Madison Powder Coating
reeper is offline   Reply With Quote
Old 08-16-2017, 10:59 AM   #27
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Yes, that is correct...
Plus, most people who have noticed this issue can actually see the bolts backing out...so you could even do a quick visual inspection first. The bolts have to back out a decent amount before they could fall out.
Old 08-16-2017, 11:08 AM   #28
vtirocz
vtirocz's Avatar
Could you confirm with your dealer if both the hub AND axle side require the new bolts, or just the axle side?
I read the TSB and it's not 100% clear to me, although I think it's only referencing the axle side.
