06-08-2019, 10:35 PM | #1 |
Drives: ZL1 1LE A10 Join Date: Mar 2015
Cut and weld NPP to new exhaust?
Has anyone tried cutting the factory NPP off their stock exhaust and welding it into an aftermarket exhaust?
Any issues? I know Borla has a NPP exhaust but I'm thinking about going with AWE or Corsa. Thanks
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
06-08-2019, 10:42 PM | #2 |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
The butterfly in the NPP is only half the system. The muffler has to have the dual chamber/ straight pipe section that allows the bypass, at that point you would be buying a NPP exhaust system.. Bottom line you can’t use a standard muffler
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD Last edited by Memphis SS; 06-08-2019 at 11:09 PM. |
06-08-2019, 10:46 PM | #3 |
Bummer. Thank you
06-08-2019, 10:52 PM | #4 |
No problem.. Borla makes a nice NPP upgrade by the way
2011 Camaro 2SS 2004 Corvette CE SOLD Last edited by Memphis SS; 06-08-2019 at 11:10 PM. |
06-09-2019, 10:50 AM | #5 |
Geez angrybits, just buy an aftermarket exhaust system for your ZL1 1LE. It will be a lot easier!
06-10-2019, 08:44 PM | #6 |
ZYJ
Drives: 2017 1SS Camaro/6 speed Join Date: Sep 2014
Borla has this NPP pipes which you can use to add the NPP to any of their exhaust system that did not come with NPP originally (S type:11920, Atak:11921)
https://www.borla.com/products/camar...rt__60605.html I am going to try to cut the stock pipe from my NPP, and weld them into my 11921 Atak with NPP deleted. It should work. Anyone wanna give some inputs in regards to this?? |
