09-24-2020, 04:31 PM | #1 |
Dyno Show Queen LOL
Zl1 intercooler pump question
does the zl1 intercooler pump run if you hold the ignition button down like it does on the SS aftermarket setups? Or does the zl1 have to be started to run the pump to add coolant?
If not is there a trick around it to run with the car off?
09-24-2020, 05:44 PM | #2 |
Yes you can run it with HP Tuners, Aeroforce gauge and a good scanner.
09-24-2020, 05:58 PM | #3 |
Dyno Show Queen LOL
Any other way
09-24-2020, 10:07 PM | #4 |
on a 5th gen you could run a jumper wire from the IC pump relay underhood...I bet it is possible on a 6th gen also...I haven't even pulled the fuse box cover in 3 & 1/2 years to look. I might just out of curiosity in the next day or two.
09-24-2020, 11:38 PM | #5 |
You should be able to run a jumper. I'm surprised no one has made a switch for it.
09-26-2020, 06:11 AM | #6 |
I have an Aeroforce interceptor pod gauge which I can control the IC pump and radiator fans when the car is not running.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
09-26-2020, 06:19 AM | #7 |
Drives: 2017 ZL1 A10 Join Date: Aug 2009
I have it tuned with ignition on in my 5th gen Z .
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
09-26-2020, 08:40 AM | #8 |
Dyno Show Queen LOL
Okay ill try the jumper ty
09-26-2020, 05:43 PM | #9 |
Drives: 19' ZL1, BMW F80 M3 Join Date: Jun 2016
GSpeed sells a jumper for the C7 IC. I would assume it also works for the ZL1 too.
08-29-2023, 09:00 AM | #10 |
Im going to burp my IC system and want to use jumper to bypass the pump relay. I have constant voltage on the upper right slot and was wondering what other slot is needed to complete the bypass circuit or does it require jumping more than one of the three other slot at the same time?
Thanks for any info |
08-29-2023, 10:31 AM | #11 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
What I did, not the cleanest but it works
Fuse 54 is 15amp. I made a fused(15amp) jumper with alligator clips on both ends and put a pin from an old fuse in the 'non-hot' side of the fuse (it goes to the pump). the 'non-hot' side of the fuse is the side closest to the front of the car. No need for turning on the key. side notes if the pump is making noise, there is air in the system the pump will turn off if too much air in the system, pull off the jumper for a sec and connect again to restart
08-29-2023, 10:54 AM | #12 |
Thank you very much h018871 for the insight!! I don’t have alligator clips and I premade a jumper with a switch and pins already so I just took the power from the relay terminal that I knew was constant works perfect thank you again!
08-29-2023, 11:02 AM | #13 |
Geoff
good method, always more than one way to do things
08-29-2023, 11:14 AM | #14 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
When I burped the IC on my ZL1 last summer, I followed the instructions in the first part of this video.
I also purchased the fitting from Dedicated Motorsports and drank a liter of Diet 7-Up for the empty quart bottle to cut in half.
