Old 05-16-2022, 02:50 PM   #1
Cannons
Drives: Chevy Camaro Corvette Nova Blazer
ECU Pin for E85 installation
I have searched all over and cannot find a replacement ecu pin for the E85 sensor install. The kit I bought had the pink wire cut off.
Cannons is offline   Reply With Quote
Old 05-16-2022, 03:04 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Is this what you’re looking to buy?
Old 05-16-2022, 07:49 PM   #3
Cannons
Is that the correct pin that comes on an E 85 kit for a 2020 camaro? I have tried looking at pictures but can't tell. Other pictures it looks like it comes to a point at the tip?
Old 05-16-2022, 08:18 PM   #4
Trochoidal
I never had to replace this when I did my install. However, another member had an issue and this is what was used.
Here’s the thread. As mentioned in the thread, I’d also remove the butt connector, solder and add shrink tube. You could also reach out to 20Bluezl1 and get the yes or no answer.
https://www.camaro6.com/forums/showthread.php?t=589879
