Old 03-07-2017, 09:43 PM   #1
KyleL
Drives: Slow
Catch can for lt4?
Couldn't find any results on this one for the zl1's. Is it necessary like on the lt1? I'm reading this article ( http://www.superchevy.com/features/1...e_z06s_lt4_v8/ ) and they're claiming "A PCV separator, which is unique to the LT4, was developed to keep oily air from being drawn through the intake, where it could end up collecting on the back of the intake valves." Now this is an article for the c7z, so I'm not sure if it's different for the zl1.
2016 Toyota 4Runner
2017 Camaro ZL1
KyleL is offline   Reply With Quote
Old 03-07-2017, 09:50 PM   #2
E-Ray
E-Ray's Avatar
Drives: 2016 Camaro 2SS, Nightfall Grey
Not sure, but by looking at photos of engine bay, the Mishimoto catch can for the SS might work. I have one installed with my Edelbrock E-Force.
2016 Camaro 2SS, Nightfall Grey,
MRC, NPP, S/R, Nav, A8,
E-Force Supercharged.
E-Ray is offline   Reply With Quote
Old 03-08-2017, 12:28 AM   #3
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 ZL1, 2021 Corvette Convertible
I asked this question shortly after purchasing my ZL1.
http://www.camaro6.com/forums/showthread.php?t=474309
See the link to the Stingray thread.
Installing a catch can on the dirty side of the LT4 is a little more complicated than the LT1 or other LS engines. It involves some significant modification.
With GM being quick to void the power train warranty for anything that deviates from stock, I didn't feel installing cc was worth the risk. That seemed to be the consensus of those that replied to my question.
Old 03-08-2017, 07:01 AM   #4
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
This one addresses the issue.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 03-08-2017, 07:46 AM   #5
Infern0
Bring It
Infern0's Avatar
Drives: In Between
I'm mean this question legitimately as an engine novice - but considering a stock ZL1, wouldn't it have come with one if it was really needed? Especially given the performance benchmarks that have been hit with the car so far.
Infern0 is offline   Reply With Quote
Old 03-08-2017, 08:56 AM   #6
Artos
Artos's Avatar
Drives: A10 LT4
I don't think you can apply that logic to those already inclined to mod...why add a CAI, bigger SC, tune, etc?? GM already dialed the car to where it should be.
Folks who are going to mod simply enjoy it & get satisfaction on improving what GM gave them. I think most all understand the liability when it comes to warrantee...if it makes them happy, have at it.
Artos is offline   Reply With Quote
Old 03-08-2017, 09:06 AM   #7
TJay74
No they wont come with them, reason being is they have to be emptied as the gaseous oil turns into a liquid. If that can is left too long and get full then the liquid can be drawn down the hose and into the engine which can cause serious issues.
That is the main reason GM doesn't use them, they cant trust the owners to empty them regularly. They are needed though to keep the oil mist out of the combustion process.
Old 03-08-2017, 09:35 AM   #8
KyleL
Drives: Slow
I checked it out this morning and it appears as though that the 2 quick connects that would have ran into the intake on the lt1 are running into a box (similar to a catch can) on the lt4. Theres a 3rd quick connect that runs from that box to a belly on the intake tube. (maybe for ventilation purposes?) now if an aftermarket intake deletes that line running to the tube, then it's just like a catch can.
2016 Toyota 4Runner
2017 Camaro ZL1
Old 03-08-2017, 10:29 AM   #9
TJay74
The engineer side of me thinks there has to be a way to make a CC that once the oil mist becomes a liquid and is in the can that it could someone how drain past a check ball and back into the oil pan system.
Old 03-08-2017, 10:40 AM   #10
KyleL
Drives: Slow
That would be possible I'm sure except the vapors caught are not just oil. Im guessing they're not doing it for contamination purposes
2016 Toyota 4Runner
2017 Camaro ZL1
Old 03-08-2017, 10:44 AM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
The LT4 comes with a "clean side" oil separator system...and it drains back into the sump. Everyone has an opinion on this highly controversial topic...but that speaks volumes to me...
Old 03-08-2017, 10:51 AM   #12
Bow Tie Affair
Drives: 6th. Gen ZL1
The best thing you can do is pull the supercharger cover and see if there is oil in it.
Bow Tie Affair is offline   Reply With Quote
Old 03-08-2017, 11:11 AM   #13
KyleL
Drives: Slow
It does vary from the lt1 though. This is the box that the lines run to as opposed to running back into the intake like the lt1
2016 Toyota 4Runner
2017 Camaro ZL1
Old 03-08-2017, 01:28 PM   #14
Mr. Wyndham
I believe the center line runs into the intake as a vacuum feed.
