Old 06-19-2017, 12:29 PM   #71
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Originally Posted by Jason@JacFab View Post
This is probably true for the v8 intake, but not for the v6 or i4 intake.
Maybe but only the releases will tell. It's clear they sourced out to CAI Inc. though i'm not mad about that CAI Inc. makes some quality products just using the exact same design is a bit lacking in the imagination department.
Old 06-19-2017, 12:34 PM   #72
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
V6 or I4 look nothing like a CAI brand unless they totally changed things up. Look more like rotofab with the open top.
Old 06-19-2017, 12:40 PM   #73
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Right... I don't think CAI Inc has the capabilities to make an intake that looks like what's already been pictured for the 3.6 and the 2.0.
It should be noted that there has seemingly been a lot of issues with the gmpp 3.6 intakes also..
Also looks like flowmaster is entering the cold air intake world. They have an intake for the 6th gen v8 now, and the 5th gen v6. currently working on the LGX and LTG intakes.
Old 06-19-2017, 01:17 PM   #74
Evil-Bee-NH
603 Camaros
Intakes are huge money at less cost then a lot of mods most will wait and see what others have done taking 70% of the development work out of it. That being said I love how things are still being dropped on us in early summer it typically slows down til late September. I mean Mishimoto and JacFab have so much in development still I have high hopes of course we know your a one man band Jason.
Old 06-22-2017, 11:39 PM   #75
SaGa
SaGa's Avatar
Drives: 2016 Camaro RS 2LT I4
Emailed MBRP about their current exhaust for the V8 and got a reply saying in a month they are releasing an exhaust for I4 and V6 I really love the sound on the v8 version hoping the sound on the I4 version doesnt let me down!
SaGa is offline   Reply With Quote
Old 06-22-2017, 11:41 PM   #76
SaGa
SaGa's Avatar
https://youtu.be/e7K_5jgeaE8?t=5m47s Sound clip of V8 MBRP exhaust if anyone was interested
Old 06-23-2017, 05:06 AM   #77
6th_gen_gino
Drives: 2016 camaro 2.0t gray
Sounds tuff, actually looking to buy an axle back set up but I really wanna hear the exhaust with an aftermarket DP
6th_gen_gino is offline   Reply With Quote
Old 06-23-2017, 01:07 PM   #78
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
To bad the I4 will sound nothing like the V8 sound clip you posted.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 07-03-2017, 09:01 PM   #79
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
Originally Posted by cooper1965 View Post
I don't see this mentioned, maybe I missed it but @ 150.00 , its a pretty good deal.
https://skidmarkgarage.net/shop?olsP...olsFocus=false
Just need to figure out how normal folks can utilize a mixed fuel capability. (as far as tuning)
Eh. All flex fuel kits are the same. It's an ethanol sensor and some wiring. You can DIY one for half that amount. The trick is getting it to work with the newer PCM's. It won't do diddly squat without tuning.
ChicagoTommy is offline   Reply With Quote
Old 07-03-2017, 11:43 PM   #80
ChicagoTommy
I will say that they are using a different, smaller sensor than I've typically seen. It's cute that they took a pic of the back side so you can't just grab the P/N.
Old 07-04-2017, 11:52 AM   #81
Beast-Y-Blue
Drives: Hyper Blue 2016 Camaro turbo
p/n flex fuel
P/N 13577429 is the part # same one rpm is using.
Beast-Y-Blue is offline   Reply With Quote
Old 07-04-2017, 05:44 PM   #82
ChicagoTommy
$24.99 shipped on ebay.
Old 07-09-2017, 09:05 PM   #83
ChicagoTommy
Those won't work in place of the stock injectors. You would have to run a custom machined intake manifold and fuel rail. Unless they mistakenly are using a picture of regular low pressure fuel injectors, which is very doubtful since the product details list a maximum pressure of 87psi or 6bar. Our fuel system runs at 2500psi or higher.
Old 07-29-2017, 12:20 AM   #84
Evil-Bee-NH
603 Camaros
Looks like a lot of BS that site doesn't really have any valid information except tech specs. Spose they also failed to mention the increased cost and issues with the 2017+ tuning makes it even less legit.
