07-28-2020, 08:11 AM | #29 | |
Mike
Drives: 2018 1SS 1LE Join Date: Nov 2014
07-28-2020, 12:55 PM | #30 |
Drives: 2013 C6Z06 Join Date: Nov 2016
07-28-2020, 06:56 PM | #31 |
Drives: Chevy Camaro Join Date: Nov 2019
07-28-2020, 08:00 PM | #32 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Tons of life left in these btw. Enjoy! |
08-02-2020, 03:23 PM | #33 |
08-16-2020, 11:24 AM | #34 |
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
Two questions:
1) once those little wear dimples (on the outer 1/3 of tire) disappear, how long til the cords? Not sure I’ve seen this answered... I’d hate to throw away the best portion of tire but also don’t wanna hit the cords first session of the next weekend. 2) is it reasonable to swap just the fronts since they naturally wear faster and then wait to do the rears? Thanks guys!
08-17-2020, 10:01 AM | #35 |
You can and absolutely should just swap your fronts. Most of us go thru fronts 2x as fast as rears. Also I've never seen the dimple gone so if you are actually that far I can't believe you haven't corded the outside edge. The outside grooves can be slick and still have plenty of life, but those dimples are the end of the tread depth. Can you post a picture of your tires?
08-17-2020, 02:02 PM | #36 | |
funny that you say you swap fronts and not rears bc a PCA instructor (GT350 owner) told me that I shouldn’t swap just the fronts bc I could end up with an adhesion differential front to rear ... I said that it made sense ... but since you’ve done it, I also believe you lol. Maybe keeping the same compound is enough to keep the delta reasonable.
08-17-2020, 02:41 PM | #37 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
TheRealJA105
What hot pressures are you running? Are you running G1F3 R or non R? Last one: What alignment settings are you running? I'm running street Front total toe 0.20 (in) camber -1.2 caster 9.3 Rear total toe 0.14 (in) camber -1.5 At the track, camber plates adjusted to -2.3 which pushes total toe to ~ -0.2 (out) 37-38 psi front & 35-37 psi rear hot At the track it looks like I could tolerate a bit more camber both front & rear It doesn't appear as though I'll cord the insides at my current settings This is after 3 track days and ~ 3000 miles on these tires
08-20-2020, 02:28 PM | #38 | ||
Hard to get a good view of your tire wear with the pic being so close but it does look like you are mostly slick on the outter tread with some life left shown by the dimple depth. However if i am seeing it right it looks like the smaller outside grooves are still on the edge, showing that you aren't pushing the tire hard enough. Try to take a picture more like h018871's. Quote:
Your tire wear looks exceptional so far. You are the first one i've heard of that is having success by adjusting your camber plates between street and track. Everyone says it throws the toe too far out to even be worthwhile. Even the ZLE guys state that rotating their top hats does this. |
08-20-2020, 03:42 PM | #39 |
Drives: 2019 2SS 1LE Join Date: Aug 2019
Interesting you all are also seeming to get a little more wear in the middle of the tire. I thought I was simply running pressures too high on the track / street, but maybe that's just how the G3 wears.
08-21-2020, 07:43 AM | #40 | |
08-21-2020, 03:07 PM | #41 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
08-21-2020, 03:37 PM | #42 | |
Geoff
