02-03-2021, 07:18 AM | #29 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
B. No just a Bachelors degree C. The engine is not offset D. If you think you want your engine flying around the engine bay, why don't you just fully disconnect your motor mounts? Disconnect your sway bars while you are at it too. That will make your car ride smoother and move more weight the opposite direction just like YOU want. E. Just stop
Old Ride: 2016 Callaway SC630 Camaro SS
02-03-2021, 07:51 AM | #30 |
Drives: Turbo 6.2 Join Date: Feb 2019
I installed my mock up engine with the mounts and it seems to be in the same exact location. I even emailed them to make sure before purchasing.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
02-03-2021, 05:24 PM | #31 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Just got the BMR mounts let see if I can install them this week.
02-03-2021, 06:21 PM | #32 |
Drives: 2017 Camero ZL1 Join Date: Nov 2015
I've had poly mounts on a 4th gen and C6Z. Didn't notice any added NVH. Wish I knew about these before I did heads/cam since they save a good chunk of weight.
2017 ZL1 A10
Dyno/Quarter Mile/Dragy 9.71@141.2 MPH so far. 2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold. |
02-03-2021, 06:40 PM | #33 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
NICE !! Remember to weigh them and compare to the stock ones.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
02-03-2021, 07:13 PM | #34 |
02-03-2021, 09:05 PM | #35 |
Drives: HBM ZLE Join Date: Aug 2017
02-03-2021, 10:04 PM | #36 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
+1 And of course this too...
02-04-2021, 12:30 AM | #37 |
So the best deal anywhere is directly from RDP and there a a promo code BMR12D. Tbey have them in stock and ready to ship.
So I started installing the passenger side first because that is the side I had with no header installed. Let me start by saying don't attempt to do the BMR mounts without removing the headers. It will almost be impossible even though BMR instructions do not mention to remove them. BMR instructions are pretty good tbey are just missing a couple of details that they do not mention or show on the pictures. You need to have a jack with a peice of wood so you can jack up the motor to relief pressure. I use a 2x6 of wood and a 2 ton jack worked perfectly. Also just to mention everything is done with car on a Quick Jack. 1. Removal of headers stock or aftermarket. 2. Removal of starter ( Don't need to but gives you alot more space to remove old mount) 3. Jack motor up a little 4. Remove a 10mm bolt that is holding coolant line, 3 - 15mm bolts from the mount to the motor ( don't reuse them) 5. Remove 2 - 15mm bolts to the subframe (SAVE BOLTS) 6. Jack motor up until you see mount loosen up. 7. There are a couple of clips that the BMR instructions don't tell you to remove that are clipped to the mount. 8. Remove the OEM motor mount 9. BMR instructions image 22 and 23 are tricky because they don't tell you to remove a 13mm bolt to a bracket holding wire harness. SO REMOVE 13MM BOLT AND ALSO THE 15MM BOLT FOR THE GROUND. DONT REUSE BOLTS. 10. Install BMR mount with loose aluminum spacer. Spacer goes ontop of the wire harness bracket not the ground bolt. 11. BMR instructions show wiring harness over mount I decided to leave it under so it can be further away from the headers. 12. Tighten the 4 long bolts provided by BMR. They are supposed to be torqued to 43ftlb but it's almost impossible to get a torque wrench in there. I tighten 3 out of the 4 with the torque wrench. Also I decided to put a tiny bit of lock tight just incase. 13. Install bracket to subframe with factory bolts and tighten. Don't tighten the BMR 24mm bolt yet incase you need to jack up to do driverside. 14. Lower jack all done now do drivers side. Weight BMR 5.5 LB OEM 7.3 Both bmr mount 9.8 |
02-04-2021, 06:52 AM | #38 |
Soooo much more room with both the MM010 style and the headers removed
02-04-2021, 07:08 AM | #39 |
Looks like both top bolts on the passenger side has ground straps, is that correct? I dont remember seeing that when I pulled my motor.
02-04-2021, 07:22 AM | #40 | |
02-04-2021, 10:24 AM | #41 |
02-04-2021, 10:25 AM | #42 |
