Old 10-27-2020, 07:48 AM   #1
LSA
Drives: Fast
C&R External Oil Cooler and Intercooler
I'm working on gathering as much info as I can related to the C&R external oil cooler and intercooler.
If you're not familiar with the setup, the oil cooler replaces the secondary intercooler for the supercharger circuit. The one in front of the RF tire.
This should drop oil temps dramatically, but the questions is what happens to IAT? Particularly if running higher than stock boost.
Again, I'm working on gathering data at this point. I have some info provided by C&R that I can post later.
If you have any knowledge of or experience with this setup, please post. I'm hoping I can put a parts list together for bypassing the stock oil cooler etc.
LSA is offline   Reply With Quote
Old 10-27-2020, 02:15 PM   #2
Tim M
Drives: 2018 Camaro SS 1LE
In OEM configuration - the right front cooler remains a engine coolant heat exhanger. The left front cooler is the supercharger exchanger (along with the larger center mounted exchanger).
Obviously your IAT's will rise with less cooling capacity. Good Luck!
Tim M is offline   Reply With Quote
Old 10-27-2020, 02:27 PM   #3
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Correct, you would upgrade the center cooler the same time... we'll see how this works out for those trying it out early.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 10-28-2020, 02:39 PM   #4
LSA
Drives: Fast
Correct. Thanks for catching that mistake.
Comparison of the OE intercooler and C&R unit:
OE HE Specs:
30 Cooling Tubes
16mm thick
242 sq in core face
Single Pass
C&R Specs:
47 Cooling Tubes = 56% increase
27mm thick = 68% increase
260 sq in core face = 7.4% increase
Single Pass
The concept overall makes sense. It remains to be proven that a single heat exchanger (intercooler) can replace 2- especially with greater than stock boost.
The thicker intercooler will also reduce flow to the primary radiator. I think not having the oil dump a bunch of heat into the engine coolant will more than make up for this, but.....
Old 10-28-2020, 08:42 PM   #5
travislambert
travislambert's Avatar
Drives: '17 ZL1
No, it's proven. I did the track testing for this C&R oil cooler / heat exchanger setup (In fact, the oil cooler was my idea I brought to C&R for them to build.)
No worries on the IATs if you upgrade the center cooler at the same time. I have lots of before and after data and there was no difference because the cooling in that circuit is more limited by the bricks in the supercharger than the front heat exchanger. If you want to test this theory, block the left cooler with cardboard and run on the track. (I did) You'll only see a few degrees difference in IAT2s. Once you upgrade the center cooler, you don't need the left aux cooler and it's still as good or better with respect to IAT2s.
The oil cooler is just amazing! I couldn't be happier with it. The temp drop is a minimum of 50 degrees. My thermostat in the Improved Racing sandwich plate is 212F, and for most of a track session my oil temps are bouncing off the thermostat. The highest oil temps I've ever seen since the install were in the 230s. Prior to the install I'd often see oil temps 290F+.
Here are some pics of my oil cooler install (and some other misc pics).
https://drive.google.com/drive/folde...vW?usp=sharing
FYI, I left the stock oil cooler (heater) in place. I originally planned to remove it, but after testing I realized the removal was unnecessary.
(I'm not affiliated with C&R Racing in any way. I'm just a very happy customer. Those guys are seriously talented engineers with some of the very best coolers available.)
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 10-28-2020, 09:14 PM   #6
FrostZ
FrostZ's Avatar
Drives: 2019 A10 ZL1
The install and cooler look awesome on the car, great work! I'm glad to hear the cooler seems to solve the problems of temps on the car as I've also been looking into this cooler for track use and couldn't find any real world data or users yet. Your data seems extremely promising and I will more than likely undertake the project this winter. Now I just have to decide between a sandwich plate or the oil to water cooler delete.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
FrostZ is offline   Reply With Quote
Old 10-28-2020, 09:24 PM   #7
travislambert
Drives: '17 ZL1
Probably can't go wrong either way.
Seriously, I couldn't be happier with this setup. I'm a very picky and data-driven person. If it didn't work well, I'd be the first to admit it. (C&R wouldn't have offered it for sale either.) I'm honestly blown away with how well it works. It's a bit pricey but after owning it, I'd call it a bargain even at double their price.
Here are some things I used for my install:
  • Improved Racing (M22x1.5) sandwich plate (212F Thermostat)
  • 10ft of -10 AN oil cooler line. 8ft would have probably been more than sufficient.
  • 3x Heavy-duty zip ties
  • 1x Straight -10 AN hose end
  • 1x 60-degree hose end (JEGS 110039)
  • 2x 45-degree hose ends (JEGS 110013)
  • 3/4 Heater hose with molded 90
  • 1x Gates 3/4 heater hose 90-degree fitting
  • 2x Gates Power Grip Hose Clamps (32929)
  • 2x Spring clamps for 3/4 heater hose
I'm not 100% sure if the two 45 degree fittings will be right for everyone. I don't have primary cats and that's what worked the best for the line routing. With the cats in place, the routing of the oil lines will need to be a little different.
2017 Camaro ZL1 M6
Old 10-28-2020, 09:57 PM   #8
FrostZ
FrostZ's Avatar
I know the feeling I'm the exact same way, gotta have every option and all the data in front of me before any decisions are made. I'm glad everything is nice and cool now so you can enjoy the car to it's fullest. Thank you so much for the parts list and insight on the project!
Old 10-29-2020, 10:48 AM   #9
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Travis, thank you for linking your pictures. I am considering this oil cooler per your recommendations, but damn it's pricey like you said. I wonder what taking away the auxiliary cooler will affect with my car being an SS because that cooler is an auxiliary radiator not intercooler.
Old 10-29-2020, 10:52 AM   #10
travislambert
Drives: '17 ZL1
I wouldn't think you'd end up any worse off than a stock ZL1 with only one aux engine coolant cooler. My assumption is the second aux engine coolant cooler on the SS is unnecessary.
2017 Camaro ZL1 M6
Old 10-29-2020, 12:13 PM   #11
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is this the set-up you were looking for to fix your high-temp issues? To make sure I'm understanding the solution:
  • upgraded blower primary H/E
  • substituted OEM-blower secondary H/E with C&R oil cooler
  • OEM primary and secondary radiators retained
Do I understand correctly?
Thanks, as always, for sharing.
'20 ZL1 Black "Fury"
Old 10-29-2020, 01:04 PM   #12
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
Thx for extensive group of pictures Travis, super detailed!
What are your water temperatures running after the C&R installation? What were the ambient temps during the sessions? This definitely seems to be the way to go.
Thx again
EDIT: It looks like you mounted the SC heat exchanger 'backwards' or front to back. Do I have that correctly? If so, what were your reasons for the change?
Old 10-29-2020, 06:22 PM   #13
LSA
Drives: Fast
Thank for the info and especially all the pics.
Old 10-29-2020, 08:26 PM   #14
travislambert
Drives: '17 ZL1
It's hard to get perfect apples-to-apples data, but we got pretty close. This data is from PittRace 8/2/2020 (prior to oil cooler) and 9/5/2020 (after oil cooler). The ambient temps were ~81-83F during both tests. Data window for both is the last 10 minutes of approximate 15 minute session.
You can see roughly a 50F improvement in engine oil temps:
Name:  PittRace Compare Engine Oil Temps.jpg
Coolant temps didn't change much other than the car stayed a little cooler for longer, but plateaued at a similar point below 220F.
Name:  PittRace Compare Engine Coolant Temps.jpg
Post compression air temps were about 5 degrees higher than intake air temps. (BEFORE)
Name:  PittRace IAT Before.jpg
After removing the left aux cooler and installing the C&R upgraded center cooler, there was no meaningful difference in IAT2s (AFTER).
Name:  PittRace IAT After.jpg
2017 Camaro ZL1 M6
