04-16-2019, 07:07 PM | #1 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Alignment specs for 1LE
Looking to get some opinions on best alignment specs for mixed use street and road course (not autocross). Suggestions? Thanks
"Make yourself sheep and the wolves will eat you"
04-17-2019, 04:17 PM | #2 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Look closely at the first two posts
https://www.camaro5.com/forums/showthread.php?t=71994 Something else to think about is how to reduce understeer. Justice Pete suggests going with a stiffer rear anti-sway bar or putting the ZL1 front bar on your 1LE. Choice is highly dependent on the tires you are running.
04-17-2019, 04:31 PM | #3 |
https://www.camaro5.com/forums/showthread.php?t=544483 post 13 has what was the last set of alignment specs that Justice Pete posted. There are typo's in the oem specs but the rest seems to match what Pete recommended.
04-17-2019, 06:59 PM | #4 |
Thank you guys. Appreciate the links.
04-23-2019, 10:43 AM | #5 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
I'm running -1.7 degrees on the front, and -0.8 on the rear with no toe up front and .125 toe in at the rear each side (for 0.25 total).
With a dozen auto-crosses per season (averaging 8 runs per auto-cross) and the rest being daily driving (10K miles per year give or take), I'm still wearing the outsides before the insides. I will try to go more camber in the front next time out (I'll try for 2.0 but will settle for whatever I can get). I would like more turn-in too, so will go with more rear toe-in or might go a little toe-out at the front.
My thoughts on some things:
