05-27-2021, 05:15 PM | #1 |
Drives: 2021 Camaro LT1 Join Date: Aug 2013
E85 AFR gauge help?
I'm looking for a gauge for monitor my E85 percentage and my air to fuel ratio. I was lead to the one linked below, so that I wouldn't pay for an extra ethanol sensor, since my Camaro already has the LethalGarage flex fuel kit.
This has me very confused. Anyway, I guess my question is, by purchasing this, how do I hook it up to read my Ethanol content? Does it plug in to my LethalGarage flex fuel kit? Thanks in advance for the help! https://www.summitracing.com/parts/inn-3910 |
07-03-2021, 03:58 PM | #2 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Just saw this one.
Not sure if you've got a way to monitor your Ethanol percentage yet, but the easiest way is to monitor through the OBD-II port using something like a Banks iDash guage. It's one of the parameters "ETHANO" that the gauge supports
07-03-2021, 07:24 PM | #3 |
Bingo. Use the AEM canbus compatible wideband in one pod, then the iDash to monitor everything else (like E content). Here’s my setup:
