04-07-2020, 01:17 PM | #29 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
My concern with this mode is the risk of water intrusion either from driving in the rain or washing the car. Can someone who has done this mod provide an assessment of that risk?
04-07-2020, 01:32 PM | #30 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Thx for the pics CDFF
I found this trim tool quite helpful to get the clips to release. I don't use the long ones often, but they do come in handy. I bought them a long time ago on Amazon, now they're at HF < $20 https://www.harborfreight.com/automo...-pc-63639.html
04-09-2020, 02:07 PM | #31 |
Coupe Newbie
No comments on the potential for water to get sucked into the engine with the blocker removed?
04-09-2020, 05:55 PM | #32 |
Guess not hawk02! That’s my concern too!
04-09-2020, 08:26 PM | #33 | |
Drives: 2018 ZL1 1LE Join Date: Jan 2020
Even with the blocker removed this car has the least access to ‘fresh air’ that I’ve ever had. That’s why I posted that picture of one of my other cars and how direct the air came in for that one. Maybe ill try and post some more pictures to illustrate my point... |
04-09-2020, 09:13 PM | #34 |
CDFF is correct...there is still a bit of a turn before the air box. It is truly more of a "snow blocker" as described in earlier posts. GM calls it a shield and I see no reason for it. I also decided to cut the piece instead of removing it entirely. The part attached to the radiator support was annoyingly stubborn and cutting it left a perfect result. Pics are difficult but #1 is the shield through the grille which I never noticed. #2 Shield in place. #3 Piece removed after cut
04-09-2020, 09:42 PM | #35 |
Coupe Newbie
Thanks, CDFF and Stephen12ZL1. This is the info I was looking for.
04-09-2020, 10:26 PM | #36 |
Here are some pictures comparing 2 650 HP cars’ intakes. One has a very small opening, is pretty indirect to get fresh air and uses a supercharger. The other has dual intakes and has easy access to fresh air. No supercharger required.
04-10-2020, 09:57 AM | #37 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2015
Hi guys can anyone confirm that SS cars have this also? Looks like a easy mod. Thanks in a advance.
04-10-2020, 05:42 PM | #38 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Pulled mine out today, took about 20 minutes and half of that was wrestling with three plastic fasteners that actually hold the shield/blocker in place.
I tried using my silicone (plastic?) trim removers but that wasn't very effective. The best tool by far was the screwdriver type that was mentioned earlier in this thread. I was able to use a six inch version though. FYI, the "blocker" is very thin plastic - you can cut it with a utility knife very easily. |
04-10-2020, 08:46 PM | #39 | |
Coupe Newbie
04-11-2020, 08:42 AM | #40 |
hawk02, did you have a chance to drive it around after you took the blocker out? Does it make a difference? I’m thinking about doing it but not sure if it’s worth the time and effort.
04-11-2020, 12:13 PM | #41 |
I can't see it making any perceptible difference just driving around...Seriously, how could it? I have an assumption it may make more of a difference at higher speeds because of a slight ram air effect.
04-11-2020, 01:17 PM | #42 | |
Coupe Newbie
With that said, here are my perceptions after removing the blocker:
Overall I think removing the blocker makes some subtle performance improvements. Considering the only cost is about an hour of your time, the mod seems to me to be a no brainer. If you live where it snows a lot and your Camaro is your daily driver, it probably isn't a good idea to remove the blocker. The gain isn't worth the risk of getting snow and ice inside your intake.
