12-13-2020, 12:31 PM | #71 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
As you alluded to, maybe the seals and dust boots have a higher temp capability for the CCM brake package.
12-13-2020, 12:32 PM | #72 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
not sure what you mean by 'insert', the J57 pistons I got are one piece. Although 3 different diameters
Could be a seal difference. I used the stock ZL1 boots and I checked, they are the same boots as used on the 5th gen Z28.
12-13-2020, 01:00 PM | #73 |
The part with the vent holes, it is an insert. It will come out of the main piston body. At least mine did. And from the looks of the yours, the one at the right, there there looks to be a tiny gap where the insert and the piston body meet, an indication of two separate pieces.
12-13-2020, 01:10 PM | #74 |
This is a zoomed in pic of my above caliper. The center insert is on its way out of the piston, notice the larger gap, compared to the bottom piston, the insert is in the piston more.
And here is one of the seals that were original to the C& ZO6/GS calipers
12-13-2020, 01:21 PM | #75 |
Geoff
facepalm moment
all of the ones I have are tight, HOWEVER, they are made of two different materials (how they make them hollow I guess). the vented portion is magnetic and the body of the piston is non-magnetic.
12-13-2020, 01:23 PM | #76 |
They are a very tight fit, it's easy to miss! I just happened to notice it when I started to disassemble mine. The pistons must be aluminum, and the inserts a magnetic grade of stainless.
12-13-2020, 02:00 PM | #77 |
Geoff
I would bet they're titanium or a non-magnetic stainless body. They're very light.
BTW the original (in my case J6H) pistons are non-magnetic also
12-13-2020, 02:13 PM | #78 | |
Drives: 1LEs Join Date: May 2009
If you have a stock J56 front piston handy, or someone have a J6M SS 1LE front out and about, measure it to see if it's 30mm height. As FYI, all the big fronts (including the carbon ceramics) mentioned use the same material and same PN outer dust seal boot kit. |
12-13-2020, 03:05 PM | #79 | |
12-13-2020, 03:10 PM | #80 | |
12-13-2020, 04:40 PM | #81 |
cdb95z28 - I saw where you had J56 fronts. I was saying what I thought would be the difference in the two listed front vented piston kit PN’s.
12-13-2020, 05:55 PM | #82 |
Cool, yeah, good info!
12-13-2020, 07:07 PM | #83 |
Geoff
Thermally, I suspect aluminum makes sense. Although, for the $$$ I'd feel better if it was titanium.
12-13-2020, 07:17 PM | #84 |
haha, yeah, I hear ya!
