12-17-2018, 09:29 PM | #29 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
got any pics of it?
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
12-18-2018, 05:19 AM | #30 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Clearly, I'm in, PM sent.
12-18-2018, 08:28 AM | #31 |
Drives: 2019 ZL1 A10 Black Mosaic Join Date: Nov 2018
I am interested also.
12-18-2018, 10:15 AM | #32 |
Drives: 2017 ZL1 Join Date: Nov 2009
I am interested in this bracket as well.
12-18-2018, 01:07 PM | #33 |
Drives: 18 Tahoe RST, 19 Z06 Join Date: Apr 2017
I'm installing a Magnusson 2300 soon. It might be time to add a catch can as well.
If the can is mounted in the radiator area, will the hoses still work or will they have to be reworked? |
04-16-2021, 02:20 PM | #34 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Old Thread Alert
I looked on the WeaponX website and did not see any catch can brackets for a front engine mount, not on elite's site either.
Did the front mount bracket get made?
04-16-2021, 02:29 PM | #35 |
Drives: 2014 Chevy Silverado Join Date: Mar 2015
I’m interested as well. I will be ordering a catch can as soon as my build is accepted. I ran an elite on my GS with success.
Order #ZNXKNK Future 2022 Riverside Blue ZL1 1LE
2016 White C7 Stingray (Wife's car) 2014 Black Chevy Silverado 4x4 Previous cars 2017 C7 Grandsport, 2014 Camaro 1LE, 2008 EVO, 2001 Viper, 2004 BMW M3, 2003 Mustang Cobra, 2002 Z06, 2002 Camaro SS, 1998 Mustang Cobra |
04-16-2021, 04:07 PM | #36 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Yes they are making a front bracket, email them
04-16-2021, 07:20 PM | #37 |
Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Interested too.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
04-28-2021, 11:41 AM | #38 |
Geoff
Move Elite Catch Can to Front
The reason for moving the can to the front is to make room for an intercooler reservoir. The original location is on the driver's side tower brace.
I got the mount location idea here on the forum, can't find it now to give proper credit to the member. When I find it, I'll update. I had a 'hockey stick' bracket from Elite off of another car, it worked out well. The only trick was that I made a bushing to fill in the gap between the slot and mounting bolt. Started with a nut and ground the points off until it would fit in the slot, Obviously start with a nut that fits over the bolt threads. I was lucky that the nut was slightly thinner than the thickness of the bracket, but it would have been easy to grind it down to fit. It clears the rain guard and hood, close but it does clear.
09-01-2022, 05:29 PM | #39 |
Drives: Camaro gen 6 zl1 1le Join Date: Jun 2022
Hello Guys
I want a catch can but I don't know which one is better for me mighty mouse or elite engineering ex2 catch can I want a plug and play kit and don't cut any hoses For my lt4 I have rotofab intake Kooks headers 1 7/8 200cpsi HJS cats Ported x kong supercharger 2.30 pulley 103mm tb nw So I want the cach can Near the radiator not of the site from headers can anybody send me link which one is the right version from my car I saw few catch can but I don't know which one is good for me i don't have 1000 whp setup I just want a good catch can with a closed system I think it's better for me and for the police hear if there oben the hood... Thanks for your support guys sry for my bad English edit: is the PVC diverter included in the elite engineering ex2 system ?? Last edited by Marozl1LE; 09-01-2022 at 07:09 PM. |
09-03-2022, 08:43 AM | #40 | |
Drives: 2010 Camaro Join Date: Nov 2009
The E2-X and E2 systems are far more than just "catchcans". They are true air/oil separating crankcase evacuation systems that provide the same functions as a belt driven vacuum system like all forms of Professional racing use, except these are designed for the street.
They are not only the most effective air/oil separating design on the market (the Ultra is app. 95% effective at stopping the oil vapors and other suspended "gunk" you don't want ingested...no other design comes close) but provides added vacuum from the Venturi Vacuum Valve when needed most so pressure should never build to begin with. All with a closed emission compliant system (not CARB cert in CA. yet). The E2X Mounts in the area in front of the engine as shown: https://hosting.photobucket.com/albu...ps4zu5rbtf.jpg And the Ultra has more capacity than the others: https://hosting.photobucket.com/imag...M_vs_Elite.jpg Our special zero cracking proprietary high flow checkvalves automatically detect when more vacuum is needed and will open and close as needed to always provide the proper amount of full time vacuum while preventing any boost pressure from back flowing into the crankcase. For your application the E2-X Ultra dual valve with the high flow checkvalves will be what you want. If you have retained the factory Clean Side Separator (located on the front of the passenger side cylinder head) you may opt to not add our billet CSS, but if you wish both the CSS replaces the oil fill cap and a line from it is "T'd" into the center line that connects to the factory one for the ultimate solution. To order the Ultra system email Sales direct at: Sales@EliteEngineeringUSA.com For ANY technical questions or to determine which of our models is best for any specific application, always email Engineering and Tech Support direct at: Tech@EliteEngineeringUSA.com and were here to assist. Note: The jet boat tour boats at Niagra Falls run multiple ZL1 engines in the boats and they run at near WOT constantly and our E2-X Ultra systems were chosen to keep those engines alive and extending life. Just another example of the function of these systems. Catch Can Comparison Mightymouse vs Elite Engineering Ultra MightyMouse Catch Can vs Elite Engineering Ultra Catch Can, which one catches more oil, which one is better? The Elite catch can is designed by Tracy Lewis P... www.youtube.com |
09-03-2022, 12:03 PM | #41 | ||
Drives: 2019 ZL1 Join Date: Mar 2019
Can we just let this topic die already? Its been beaten so much there's nothing left. And honestly, vendors shouldn't be in this forum trying to push their products.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-03-2022, 01:37 PM | #42 | ||
The Elite can is the clear winner in these tests, PERIOD |
