01-21-2019, 08:12 PM | #1 |
Steel brake lines for any SS 1LE guys?
Anyone know if the steel brake line kit from Goodridge is quality and worth the upgrade for the track? My brake feel is not the best....I have the upgraded fluid in there, but still kind of soft on the pedal.
2022 Camaro Zl1 1LE, e85, Roto Fab and tune
2020 Colorado ZR2 Dusk edition 2021 Mustang Mach e |
01-21-2019, 08:55 PM | #2 |
Drives: SS-6-SPD Join Date: Jan 2017
I heard it’s not much but does help. I’m actually upgrading as well.
01-21-2019, 09:31 PM | #3 |
Who Needs to KNOW?
Stock lines are steel.. just nicely coated in durable rubber coating.
ing for grip.
01-22-2019, 01:31 PM | #4 |
i have the phastek ones and they are good but i only have a 1ss lol
01-22-2019, 01:46 PM | #5 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Currently there are no stainless steel braided lines for the SS 1LE.
Goodridge is working on a set, but not sure when they will be out. https://www.camaro6.com/forums/showthread.php?t=537713 Last edited by thescreensavers; 01-22-2019 at 09:25 PM. |
01-22-2019, 04:31 PM | #6 | |
Drives: '18 Black SS 1LE; '01 Corvette Z06 Join Date: Nov 2018
Either way, I've run Goodridge braided lines on my race-prepped C5Z for years and I like the extra robustness (is that a word?) over the stock lines, especially after seeing stock brake line failure on a friend's new C6 GS. I'm not seeing a lot of options other than Phastek, but I think I'll wait for a brand like Goodridge that I am more familiar with. Has anyone found them for the SS 1LE yet? |
01-22-2019, 08:15 PM | #7 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
The OEM lines are steel.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-22-2019, 09:21 PM | #8 |
Who Needs to KNOW?
I've seen aftermarket "stainless" type fail often due to poor installation as many are MISSING stock locating brackets, twists and kinks again from poor installation. Stock lines, i've seen them fail internally but that was on cars that were 10+ years old. Those same locating bracket rust and squeeze flow to caliper, eventually leading to stuck caliper, again, old car in rusty environments.
On such critical safety item, no OEM in their right mind would skimp on quality. I find it hard to believe that OE line failed w/o some user help.. ie dropping a wheel on the brake lines as wheels are swapped, etc. Twisting line when doing brake job cuz noobz
ing for grip.
01-22-2019, 09:27 PM | #9 | |
We are talking about the last bit by the caliper thats rubber
01-23-2019, 08:34 AM | #10 | |
Stock brake lines are made for the 90% who will not heat their brake fluid to the max temps allowed by high-temp fluid like Motul or SRF. Ever seen a stock aluminum caliper "spread" due to heat? Is it because GM skimped on quality or b/c the design parameters did not include sustained temps allowed by high-temp brake fluid? No one is holding a gun to your head forcing you to buy braided lines. Drive the stock ones. For me the brakes are THE most important thing on the car and I will have the best available brake lines on my car, which are not the ones that came on it. |
02-06-2019, 03:52 PM | #11 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
I have the phastek set. Theyre ok, not as big of a difference as doing the lines on my frs.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
02-06-2019, 04:55 PM | #12 | |
yea i have em 2 probably upgrade to the goodridge ones
12-05-2019, 03:12 PM | #13 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
For the SS 1LE, it shares the same brake lines as the ATS-V (front/rear), according to GM parts. The rears are the same between SS, SS 1LE, ZL1 and ZL1 1LE according to GM parts (as a point of consideration). Once it comes in, I will update this thread with information and pictures. |
12-05-2019, 03:38 PM | #14 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
interested
