12-02-2020, 03:47 AM | #1 |
Madman
Drives: 2018 2SS Optioned 6spd Summit White Join Date: Aug 2020
Whats this? -jack
I attached a photo of the “box” on the left side of engine towards front
I got a catch can thinking that took care of the Pcv relating to the cleanliness of the air entering engine but there seems to Be a second Pcv system ? Thanks 2018 2SS |
12-02-2020, 06:37 AM | #2 |
Looks like the factory oil separator system to me.
12-02-2020, 07:24 AM | #3 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Yes, its the factory, dirty side (if i remember correctly) oil seperator. The oil it catches is routed back into the oil pan. Your clean side catch can is still needed, if you believe in catch cans.
12-02-2020, 01:05 PM | #4 |
Madman
So this is a factory catch can?
12-02-2020, 01:08 PM | #5 |
Madman
Thx for replies btw
Do u not believe in catch cans ? Mine fills up (3oz) after 5-7k or so I was asking what that part is because I would like to know what it does and if it can be removed? Perhaps removing it would keep intake components and passages cleaner ? This curiosity came after I installed a vented cap, anyone have any experience w vented caps catch cans and Pcv etc? Thx again |
12-02-2020, 01:09 PM | #6 |
Drives: like an old lady Join Date: Jun 2012
it is a factory catch AND DRAIN can. it works poorly, letting a lot of oil by and it drains what little it catches right back to the oil pan. its worthless.
be careful with those fittings. i had to replace that thing on my car, it was a huge pita to change a plastic part that really doesn't do anything.
12-02-2020, 01:10 PM | #7 | |
12-02-2020, 02:44 PM | #8 |
Drives: 2016 2SS Convertible Join Date: May 2012
That’s the “clean side” air/oil separator that feeds clean fresh air to the valve covers. The “dirty side” is the PCV hose running from the engine to the intake manifold. That’s where the majority of the oil will be captured by a catch can. I had one on my 5th Gen and moved it to my 6th Gen. Mine collects about 4 oz. of fluid per year. To each their own but I’m a fan. I remove it and replace the factory PCV hose before taking it to a dealership.
12-02-2020, 03:07 PM | #9 | |
12-02-2020, 03:31 PM | #10 | |
Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
12-02-2020, 04:07 PM | #11 |
Madman
How does it feed fresh air to the valve covers ? Doesn’t the intake do that ? It looks like a box, don’t see any connections to crankcase to drain back oil either, if it does then I would def want to remove it as that would make the oil dirtier faster would it not ?
Side note: Many have said that my “tone” makes it sound like I’m clowning but I’m just trying to learn |
12-02-2020, 04:27 PM | #12 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
PEGA2SS, I'll try to make this semi clear.........
Clean side only deals with oil mist that comes from a positively pressurized crankcase. This usually occurs during WOT because there is no vacuum in the manifold to purge the crankcase through the dirty side. That's why it doesn't catch a bunch of oil and GM feels as though it can drain back into the crankcase. Dirty side puts a negative pressure in the crankcase, via the manifold vacuum, most of the time the engine is running. So, it catches more oil mist. GM feels as though this oil has more contaminants in it, so they prefer to burn it rather than dump back into the crankcase.
12-02-2020, 09:07 PM | #13 |
Madman
Thx Geoff
Makes sense So since I have a vented oil cap (by Earls) do u think that piece can be deleted ? The valve covers will still be getting their fresh air and dirty oil won’t be drained back |
12-02-2020, 10:31 PM | #14 |
2020 Shadow Gray 2SS
Just don't EVER let it get "full", if you start ingesting liquid oil into your intake, that will be a VERY bad thing! I empty mine about every 500-100 miles and usually has less than an ounce of oil, but I don't want it to even get close to being full (or even half full)...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
