11-24-2020, 05:30 PM | #15 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Bumping this thread to share a different type of small light fire extinguisher that I just discovered today made by Element. The E50 model is $80 and it will fit in the Camaro glove box. I ordered the slightly larger E100 which may fit diagonally in the glove box but it would be close. I ordered 2 of their $6 quick fist mounts and plan to put it behind the passenger seat where it will be within easy reach while driving.
Since it only weights 0.79lbs I am planning to use 2 small holes in the vertical part of the carpet that would be behind your knees if sitting in the back seat to hold the extinguisher mounts. There is a current 15% off code EFHS20 plus they also offer free shipping if you spend over $99. https://elementfire.com/collections/allproducts |
11-24-2020, 06:51 PM | #16 | ||
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
From a practicality pov it would likely be best suited to be used on ya know what, after consuming too much hot salsa vs putting out any type of automotive fire IMO. |
11-24-2020, 07:21 PM | #17 |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
I went with the:
Brey Krause R-2155 Fire Extinguisher Mount - Chevrolet Camaro (6th gen) Easy to install and fire extinguisher is out of the way and full seat mobility. Best Regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
11-24-2020, 08:23 PM | #18 | ||||||
11-25-2020, 09:19 AM | #19 | |
Drives: Turbo 6.2 Join Date: Feb 2019
slow the car down safely - If your cars on fire and you can use brakes, STOP AS FAST AS YOU CAN. pull off the track. or just get the hell out of the car asap because its on fire and not worry where you park it. unbuckle your seatbelt. Yup, you have to do that anytime you exit the vehicle. reach over and unclip the fire extinguisher. No, get the hell out of the car. pull the safety pin. No, get the hell our of the car. exit the vehicle. Yup, covered that 3 steps ago. then start spraying the fire. OK. Majority of the fires I have seen are not sudden burst into flames. They are engine/fuel fires that start small and are in somewhat of a controlled situation. Number one thing to drive into people's brains are to get the hell out of the car ASAP! That's it. Once you are out, then you can access the situation and grab your extinguisher and begin spraying. 30 seconds is a long ass time when your shits on fire. I've ran over to people I was racing and pulled them out of their cars that were on fire in less than 30 seconds. If anyone cant exit their cars in way under 30 seconds, they should really be addressing that. Esp when its right side up and the doors open. #2 all the posts here are showing ways to safely bolt the extinguisher inside the vehicle. No one is saying, leave it on the passenger seat where it can fly around in a wreck.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
11-25-2020, 09:20 AM | #20 |
This is the best option so far imo. I have kids so the passenger seat needs to slide back and forth all the time
11-25-2020, 04:35 PM | #21 | |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
The Element product would seem to be well suited for carrying in the trunk of my wife's car. It doesn't take up much space and is light. I will have to have a conventional 2.5 lb (UL 1A:10BC rating) extinguisher to meet tech for BBORR.
11-25-2020, 06:34 PM | #22 | |
G9981806 - Fire Extinguisher, 1A:10B:C, Dry Chemical, 2.5 lb G4154394 - Fire Extinguisher Bracket,2.5 lb. Best regards, Dave
11-27-2020, 09:55 AM | #23 |
Geoff
Thx Dave, that's the Amerex in a different color, nice choice. I have to stick with red for tech
11-27-2020, 08:56 PM | #24 | ||
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
12-19-2020, 03:36 PM | #25 |
Here’s what I decided to do as an extinguisher setup - it allows easy swapping on and off and easy access/reach:
12-19-2020, 07:44 PM | #26 |
12-22-2020, 08:23 PM | #27 |
"..It's company policy never to imply ownership in the event of a dildo - we have to use the indefinite article 'a dildo' never 'your... dildo...'"
12-23-2020, 08:47 AM | #28 |
