08-12-2022, 06:48 AM | #1 |
2018 camaro tail light wiring diagram
Hello,
Does anyone have the pinout for the 2016 - 2018 Camaro rear connectors, 6 pin pinout? Like that (2019), but 2016 - 2018! Thanks in advance.
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights Last edited by lynyrd; 08-16-2022 at 05:32 AM. |
08-12-2022, 03:49 PM | #2 |
There are two PDF’s in this thread for 2019 tail lights. I see you asked for 2018 but this might help. IDK if there’s a difference but I can’t see why there would be a different harness/connector between the 2 years.
https://www.camaro6.com/forums/showthread.php?t=572223
08-13-2022, 11:16 AM | #3 |
The European model has only 6 pins, the rear lights have changed, from 2016 to 2018 there is one model and from 2019 to 2022 another.
And on the connections indicated on the X410 and X420 PDFs, there are 8 pins. The European left rear light has an additional fog light, which is not there on the US model.
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights |
08-21-2022, 07:55 AM | #4 |
Hello,
I installed the American taillights on my European, I had to reverse the turn signal with the reverse light. The American version has the reversing lights in the rear lights, the European in the bottom of the bumper. I tried to connect pin 2 of the bumper connector to pin 3 of the tail light connector, no light. Normally the ground is already connected in the rear light, is the ground pin of the bumper connector needed? When I leave the bumper connector plugged in, the reverse light and the bumper fog light work. When I remove the connector from the bumper and connect the ground (pin 1) and the reverse light (pin 2) or the fog light (pin 3) with a multimeter, I have nothing. If you have an idea of the problem, thank you in advance!
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights Last edited by lynyrd; 08-21-2022 at 08:32 AM. |
08-21-2022, 08:18 AM | #5 |
I'd check the wiring in the schematics, see below.
T90 is the RPO for the Europe/Asia spec lighting, the diagrams show it as a variant indicator ("T90" means the signal path is for the EU/AS spec, "-T90" means it's for the US spec). Color coding is as follows: Code:
BK Black BN Brown BU Blue GN Green GY Gray PK Pink RD Red VT Violet YE Yellow WH White
08-21-2022, 08:36 AM | #6 |
I tried to connect pin 2 of the bumper connector with pin 3 of the fire, nothing!
08-31-2022, 07:05 AM | #7 |
Hello,
Where do you think I should connect the ground from the bumper connector to the negative pole 1 or the negative lines of the position lights 2? Thanks.
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights Last edited by lynyrd; 09-01-2022 at 07:00 AM. |
