07-19-2022, 09:25 PM | #1 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Katech oil pump and cam install question
I am at the point where I need some suggestions on installing my cam, Katech oil pump and all supporting mods. I have the oil pan and pump off now. My question is should I pull the motor or remove the front bumper cover and radiator out of the way for the removal and install. Any help would be appreciated.
07-19-2022, 09:37 PM | #2 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
That question purely depends on how lazy you are feeling as far as how much more work you are willing to put in. Regardless, the level of difficulty of working on these motors escalates regardless because both ways presents their own unique challenges.
Do whichever one you feel more comfortable with doing. Me myself, I probably would try everything I could to do it in vehicle, but that's just me.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
07-19-2022, 09:52 PM | #3 |
Red Bull
Ya that’s my feeling also. It’s just difficult installing the oil pan back in place with the motor in the car. You have to jack up the motor a little. But we did it like that in my C7. Just wanted to see what other people thought. Thanks for your input
07-20-2022, 08:23 AM | #4 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
You should absolutely pull the engine if you are putting a cam in. The correct way to install single bolt LT camshafts is to brace the back of the camshaft while torqueing it. If you torque the camshaft without bracing the back of it, you run a risk of damaging the timing chain and chain tensioner.
07-20-2022, 09:06 AM | #5 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
Zach nailed it. Do it correctly and pull the motor. Much easier to do the job correctly. And I’d rather pull it than deal with the radiator/ac condenser all monkey ****ed together.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
07-20-2022, 10:25 AM | #6 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
about a half day into mine we were cussing ourselves for not pulling the motor. did the cam and pump. never want to disassemble the front of one of these again
07-20-2022, 11:28 AM | #7 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Katech_Zach: Great info! Thanks.
07-20-2022, 12:24 PM | #8 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Pull the motor if you have a hoist and stand. leave the compressor in the car so you don't open it up.
I had a friend vacuum the AC before i started and did it in the car. The only bummer was that I had to / chose to drop the cradle to get the pan off and sealed. I did not plan on it, so had to buy a cheap engine support. I do not have a hoist or stand.
07-20-2022, 12:26 PM | #9 | |
Geoff
07-20-2022, 02:18 PM | #10 |
There is a large center hole, and 2 holes on the perimeter. We made a tool that slips into the 2 perimeter holes with a half-inch drive in the center. We then can use a breaker bar to hold onto the back side of the camshaft while we torque it.
You can also get 2 dowels/bolts/etc, whatever you can find, and stick them into the back side of the cam. You could then get a large prybar to slip between the 2 pins. I am sure GM makes a tool that is located in the service docs as well |
07-20-2022, 03:14 PM | #11 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
hoping to do mine soon... Subscribed to see how yours goes. Good luck!
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
07-20-2022, 03:39 PM | #12 |
Are you also doing the VVT delete?
07-20-2022, 05:04 PM | #13 |
Geoff
Thx Zack, good info
07-21-2022, 08:36 PM | #14 |
Red Bull
Is there a way to keep the cam from moving if you install it in the car? I see a lot of shops and people installing them in the car.
