02-21-2019, 01:22 PM | #15 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
It depends on if you are worried about cutting wires/running wires from doors to trunk or doing something that is reversible. The easiest way is just do the harness at the Bose amp....no wire cutting and taking trim and door panels off to run wire to trunk...I actually made a bypass harness myself(before S*bth*mp came out with theirs) that feeds 6 Bose amp speaker out channels to my DSP...with regards to LOC vs high level to the amp...dont think it makes much difference for a sub woofer...i think that decision would be driven by your sub amp...what sort of inputs it has...
My sub box is actually from same company as the harness you are looking at...its just wedged in there...if i take the carpeted cover off that is surrounding the amps, i can actually take the sub box out after disconnecting the speaker wires...purposely did it this way so that when i have to change the battery, i can pull the side panel back or off far enough in order to access the battery
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
02-21-2019, 01:29 PM | #16 | |
Drives: 23 2SS 1LE Join Date: Feb 2019
The only other thing is the REM wire. What do I splice in to get the amp to know when to turn on? EDIT* Come to think of it, if I use an amp with high level inputs, would I need that harness at all? (The new KickerCX amps accept up to 40 volts) Could I not just splice into the front speaker wires at the amp and feed them directly into the amp? It seems like a waste of money to get the harness. The only other thing was the ANC being deactivated but unless that changes for 2019 models, I dont think the non SS even have that. (Also can't you just unplug a wire to cancel that anyway?) Last edited by RideWithDanger; 02-21-2019 at 01:47 PM. |
02-21-2019, 04:59 PM | #17 |
splicing wires vs harness...like i stated earlier...depends on if you care the wire is spliced vs using a harness where you can easily return back to factory if you take sub out.
we just unplugged the mics in the doors when the panels were off to replace the door speakers...again on that...you can unplug in the doors, cut one of each of the mic wires at the amp...or get the anc harness from said supplier...if you have the bose amp....you have anc mics in the doors if i recall..we tapped the wireless charge pad fuse for rem turn on...you could also get an amp that has input sensing where it turns the amp on...i think they even have modules that you plug in line with an rca cable that senses audio that would supply a remote turn on
02-21-2019, 05:09 PM | #18 |
I'm comfortable with splicing wires professionally enough to make it 99.9% stock if I take the sub out. If it was a $20 harness or something then maybe but the price is just too high to justify that.
I did see somewhere to use fuse #33 I believe for the REM. And yes the amp I'm planning on wouldn't NEED it but I still like the REM option better. Well, I think that covers everything. Should not be much of a problem. Other than the mics in the door but that seems like a super easy fix. |
02-21-2019, 05:13 PM | #19 |
Good Luck
02-21-2019, 05:59 PM | #20 |
Drives: 17 SS 1LE Join Date: Dec 2015
I hate subs firing in the trunk, always sounds muddy compared to a system firing in the cabin.
02-21-2019, 06:18 PM | #21 |
Yeah I'm hoping to design a box that will fire into the cabin. Also where can I find a wiring diagram so I know which 2 wires to splice into ?
02-21-2019, 06:58 PM | #22 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
Agree on forward firing subs sealed from the trunk. Have this setup in my V, perfect bass response.
I'm the wrong person to ask about cheapest way to install the system. After two audio overhauls, I'm over $15k in on audio alone .. but it's perfect now
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
02-21-2019, 07:12 PM | #23 |
02-21-2019, 08:12 PM | #24 | |
I may end up redoing everything but it will be a while. I just want to start with a subwoofer and see how I like it. |
02-21-2019, 08:15 PM | #25 | |
02-22-2019, 06:44 AM | #26 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I used a dsp and a sub thump harness on Amazon. You guys are making this way too expensive and hard, you dont need that super expensive fancy stuff unless you are a top notch audiophile. 90% of the population cant even notice. Should be able to do that with about $150. Super easy, especially if you have installed stereos before. The subwoofers will produce more bass firing towards the rear, but that's for max spl. Also, ported boxed are the absolute loudest boxes for bass as you can tune the specific frequency with the size and length of your port. I'm sure you already know that though. Dont forget to pull the mic pin on your bose harness.
02-22-2019, 06:46 AM | #27 |
You need pin 2/6 and 3/7 to tap off door speakers..GM calls the rear deck speakers subwoofers but they really are not...they are the exact same part number as the door 6x9's...
there are actually 3 plugs going in to bose amp....the door speakers are on the first on in the post i linked to...you will see in one of the other plugs the ANC mic connection...if you dont want to pull the door panels and dont care about cutting a couple of wires...you can disable the anc at the amp as to the bass roll off....that starts about 60% volume....line level converter isnt going to fix that...wont make any difference tapping high level direct to amp vs high level speaker out of the bose amp to line level converter. The only way you are going to overcome the bass roll off is to do the PAC of NAV unit to tap the most50 signal from the head unit...before the bose amp manipulates the signal...you want more bass at lower levels...you will need to adjust your amp gains accordingly.. I agree...this Bose system can be challenging and expensive to upgrade depending on what you want to do...Adding a subwoofer is one of the easiest and cheapest things to do in order to improve the sound for most...i went the full system route...had to do a 3Sixty3 DSP to fix the Bose amp outputs....its easier now with the PAC and NAV units that let you tap in to the raw signal coming out of the head unit...but those werent around a couple of years ago when i upgrade mine
02-22-2019, 07:27 AM | #28 | ||
