Go Back   CAMARO6 > Members Area > Ask the Camaro Team
View Poll Results: Ask Al Poll #5
Why did the 6th gen SS 1LE get wider tires at the rear only? 12 22.22%
Can you expand on the recommended engine oils for track use? 41 75.93%
Where is the 7 speed tranny on the ZL1/ZL1 1LE? 1 1.85%
Voters: 54. You may not vote on this poll
Old 05-23-2018, 08:38 PM   #1
May 2018 - Ask Al Poll #5
Here's the next set of questions for the team.
I know it's been a slow go but keep the questions coming so we have a good selection and we will keep plugging along.
I see some good info to gain out of a couple of these.
Place your votes....
1) Why did the 6th gen SS 1LE get wider tires at the rear only?
https://www.camaro6.com/forums/showthread.php?t=527909
Given that the 5th gen 1LE and Z/28 both ran same-size tires at all four corners, I'm wondering what changed the philosophy specifically for the 6th gen SS 1LE away from maintaining the same tire size all around and simply making the rear wheels a little wider than the fronts.
Was it a downstream consequence of the bump in power and torque? Understeer budget or breakaway characteristics reasons and the Alpha chassis? Appearance? Other?
2) Can you expand on the recommended engine oils for track use?
https://www.camaro6.com/forums/showthread.php?t=516314
In particular:
Mobil 1® 0W-40 (It's usually in stock locally and seems like a reasonable choice, but is not dexos2™ approved.)
Mobil 1® 5W-50 (It offers great protection and is possibly better for emission systems than Mobil 1® 15W-50.)
(Valvoline® SynPowerTM MST 5W-40 mentioned in the manuals is now dexos2™ approved.)
3) Where is the 7 speed tranny on the ZL1/ZL1 1LE?
https://www.camaro6.com/forums/showthread.php?t=517683
mlee is offline
Old 05-24-2018, 07:54 AM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I like the direction these questions are headed.
Voted for the oil question!
Mr. Wyndham is offline
Old 05-24-2018, 07:57 AM   #3
Voted...Oil Question.
Old 05-24-2018, 07:46 PM   #4
ChevyRules
Drives: 2021 Tesla Model 3 LR
I voted for the oils and hope if asked, the question is expanded to include whether using 5W-30 will still be considered a "good" oil and they would still honor the warranty if the new Mobil1 0W-40 ESP truly does become the factory fill. As my Camaro is street driven and does not go on the track so no need for the dual use oil.
ChevyRules is offline
Old 05-24-2018, 08:03 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Did you seriously bump a sticky?
You do realize it was already at the top of the stuck list too, right?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
DGthe3 is offline
Old 05-24-2018, 08:12 PM   #6
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
What about the GM suspension kit question? Not enough interest in that one?
https://www.camaro6.com/forums/showthread.php?t=512278
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
vtirocz is offline
Old 05-24-2018, 10:36 PM   #7
waterman
waterman's Avatar
Drives: Grandad's C2 L89
I voted oil as well.
If I may; Only Mobil 1 ESP and Castrol Edge make Dexos2 0W-40.
With that said, do the new 0W- oils address/reduce the previously known 0W- oil volatility issues in forced induction GDI motors such as excessive varnishing and coking?
If so, I am assuming that is possibly the reason that Chevy engineers have approved its use in dry sump LT4/LT1 for both road and track use.
Will that approval be extended to the wet sump versions of LT4/LT1?
(Honestly, I don't feel confident running 0W-40 on track but am interested in road use).
Mobil 1 15W-50 is not Dexos2 approved and yet is the only oil recommended for track use in ZL1 1LE, It is also OK'd for track use in LS/LT 1LE, SS 1LE and ZL1.
If according to the High Performance Supplement the oil is changed out after track use, may other high quality, full synthetic lubricants that are refined by companies that produce Dexos2 oils (i.e. Amalie/Motul) be substituted under warranty?
My apologies for the dissertation. Oil volatility in 0W- oils is my biggest concern.
Thanks for consideration.
2018 ZL1 1LE sw/PDR
waterman is offline
Old 05-25-2018, 07:12 AM   #8
Mr. Wyndham
That was on the radar. Look for it on the next poll, probably!
Old 05-25-2018, 10:34 AM   #9
shaffe
Drives: 21 Bronco
I voted oil as well. This should give an interesting and educational answer
Lets keep it simple. ..
shaffe is offline
Old 05-25-2018, 04:34 PM   #10
mlee is offline
Old 05-28-2018, 02:10 AM   #11
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
They went with easy questions after the last one i see.
Evil-Bee-NH is offline
Old 05-28-2018, 09:29 AM   #12
vtirocz
vtirocz's Avatar
Thank you!! I think GM would sell a ton of suspension kits if they offered the info I'm looking for so folks can use that data to make an informed decision on what best fits their needs.
vtirocz is offline
Old 05-28-2018, 09:37 AM   #13
http://www.chevrolet.com/performance...aro/suspension
...and yes I have questions too.
mlee is offline
Old 05-28-2018, 01:21 PM   #14
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
OIL!
soloknight6 is offline
