05-02-2019, 12:06 PM | #57 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
Thanks. I ended up ordering the Castrol, it's really not that much more $$.
I've run the Motul in bikes and cars, with stock and aftermarket brakes and I've always been happy. Most recently in a track only car on <100tw tires with big Wilwoods and aggressive pads... but it's a light car with lots of thermal capacity in the brake hardware. |
05-02-2019, 06:19 PM | #58 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Has anyone used Motul 660 over 600?
I just picked up 660 since there was no 600 available in stock.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
05-02-2019, 08:14 PM | #59 | ||
It's hard to tell differences in brake DOT4 fluid from the drivers seat. But you will definitely know when you have DOT3. |
05-02-2019, 10:38 PM | #60 | |
05-03-2019, 07:23 AM | #61 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
RBF600 is perhaps the most commonly chosen fluid when people move up to something in the 600-ish dry boiling/400-ish wet boiling neighborhood. For many people, that seems to be sufficient, so they stick with it.
660 has a little higher dry BP than 600 (617F vs 594F claimed), but depending on whose data you look at the 660's wet bp may be lower than the 600's. For that reason, 660 may take a little more maintenance in order to maintain its temperature advantage. Norm
'19 WRX 6M (the family sedan . . . seriously) |
05-03-2019, 09:15 AM | #62 | |
That, and for the price of Motul 660 you should just get castrol SRF anyway.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
05-03-2019, 10:05 AM | #63 |
Why would you do that Castrol is more expensive and I seriously doubt anyone in this group is going to experience any difference.
05-03-2019, 10:24 AM | #64 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Dry boiling point is a nearly useless measurement. In reality, as soon as you open the container, it'll no longer be at the dry boiling point and will work its way to the wet boiling point. The specification you should be looking at is the wet boiling point. Castrol SRF is the benchmark for doing it right for track prep. Everything else is a compromise. Motul 660 is a marketing trick; their RBF600 is a better fluid with a higher wet boiling point for less money. 1 liter of ATE Typ 200 is $17 w/ 396F WBP 1 liter of Motul RBF600 is $37 w/ 421F WBP 1 liter of Motul RBF660 is $58 w/ 401 WBP, a bad value given it's only a few degrees better than Typ 200 for over 3x the price. 1 liter of Castrol SRF is $70 w/ 521 WBP Pegasus has a handy chart that shows the usual suspects: https://www.pegasusautoracing.com/gr...pID=BRAKEFLUID
05-03-2019, 11:00 AM | #65 | |
That's a serious difference in WBT! Castrol is $100 a litre on Amazon.ca and the Motul 660 was $56 at my local auto parts store. No one seems to stock Castrol locally where I live in B.C. Canada Will move to Castrol SRF next for sure especially once I hit up a track that is harder on brakes.
05-03-2019, 11:58 AM | #66 | |
im upgrading from 600 to 660 this weekend was gonna do the castrol srf but its $$$$
05-03-2019, 12:36 PM | #67 | |
05-03-2019, 12:46 PM | #68 |
Sounds like you should go with Castrol SRF or stick with 600 based on what I'm hearing here on the forum, that's what I'm going to do when I get a chance
05-03-2019, 01:14 PM | #69 |
I just got two liters of Castrol SRF from Amazon for $62/liter.
05-03-2019, 01:24 PM | #70 | |
eh i dont run super hard or do alot of track days so anything better than what i have will be fine i trust my buddys shop they know there shit no doubt the castrol srf is better but just way more $$ so o well
