Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 03-22-2019, 07:01 PM   #183
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
Both days, Saturday may be wet
Old 03-23-2019, 08:10 PM   #184
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Coming out tomorrow with the plates. Hope before 11 am...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 06-25-2019, 02:22 PM   #185
BT24
Drives: 2011 2SS/RS + 2015 Z/28
1LE with trailer
What trailer and hitch are depicted in the photo?
BT24 is offline   Reply With Quote
Old 06-30-2019, 04:26 PM   #186
h018871
Geoff
h018871's Avatar
Modified Hidden Hitch and 4x6 TSC trailer.
EDIT: look at post #113 on pg 9 for detail on the hitch modification
Old 09-13-2019, 04:39 PM   #187
h018871
Geoff
h018871's Avatar
Driveshaft Rubber Coupler
The first track day since the spring is coming up and I was going over the car and noticed that there were fibers hanging out of the rubber coupler and the rubber was cracked.
It turns out that GM doesn't list a part number for the coupler, it comes with a complete driveshaft. If you have the correct part number, you can get couplers but the number is not easy to determine. My parts guy didn't have a part break down of the driveshaft assy and couldn't look at the coupler "where used".
I found this thread https://www.camaro5.com/forums/showthread.php?t=554318 after I ordered wrong couplers
The correct number for 5th Gen SS & Z28 manual cars is 92228328.
There are single use components on the drive shaft:
Nut, Propeller Shaft (6ea) 92228333, (also coupler to trans, 3ea), 1 Use
Washer, Propeller Shaft (6ea) 9222834
Bolt, Propeller Shaft (6ea) 92228335 (coupler to shaft), 67 lb-ft 1 Use, measure torque on nut
Bolt, Propeller Shaft (3ea) 92139104 (to differential), 85 lb-ft 1 Use
Bolt, Rear Propeller Shaft (3ea) 92139225 (to transmission), 72 lb-ft
Bolt/Screw, Propeller Shaft Bearing Support (2ea) 11515758, 192 lb-in
Old 10-09-2019, 02:50 PM   #188
h018871
Geoff
h018871's Avatar
not the best track day
Old 11-17-2019, 12:23 PM   #189
h018871
Geoff
h018871's Avatar
A different failure
This turned out to be the problem. The #4 intake valve head split. This is the first one the engine builder has seen..........still bad. They're working with me on the rebuild so hopefully not BIG $$$$
Old 11-17-2019, 12:26 PM   #190
h018871
Geoff
h018871's Avatar
The Fix
I put the LS3 back into the car and have decided to sell the car. I have a buyer lined up for the LS7, so that's good.
The car is listed several places, This is the eBay link
https://www.ebay.com/itm/254423651400
Old 11-17-2019, 12:39 PM   #191
h018871
Geoff
h018871's Avatar
Next?!?
I'm looking at the 6th Gen ZL1 along with both C7 Z06 or less likely the GrandSport.
I am not thinking of the 6th gen SS 1LE because I'm afraid that I'll want more power and will end up seriously modifying it..... I think I'd like a stock vehicle with a warranty for a while. Both the ZL1 & Z06 have the LT4 and should make ~550 to the wheels.......that should be plenty for a while.
I've got some time to make my mind up.
Old 11-17-2019, 05:38 PM   #192
hammdo
hammdo's Avatar
Damn, how did I miss this? ZL1 — best choice...
So, the LS7 took a dump — would not have expected that!
-Don
747 RWHP 794 RWTQ
Old 11-21-2019, 03:09 PM   #193
h018871
Geoff
h018871's Avatar
really, i agree. I was not expecting it!
it was a material failure of the valve. HOPEFULLY, things will go good on the repair. It's not apart yet, so still wondering if the block is hurt. there was water in the pan when we pulled it out. so at a minimum the head is hurt
Old 02-14-2020, 08:43 AM   #194
h018871
Geoff
h018871's Avatar
Car has been sold. I’m gonna miss it.
Hopefully it’s got a good home, may see it on a track someday..........
Old 02-14-2020, 09:24 AM   #195
hammdo
hammdo's Avatar
Wow.. let’s see what’s next!
-Don
747 RWHP 794 RWTQ
Old 02-14-2020, 04:39 PM   #196
krazzyk01
Liv'n The Dream!
krazzyk01's Avatar
Drives: 2013 Black 2SS RS 1LE
OH Man!
Man! I don't pay attention for a hot min and you've sold your car! So what's next on the play list?
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
krazzyk01 is offline   Reply With Quote
1le, 2ss, build, h018871
