Old 06-13-2018, 05:27 PM   #1
acidronin
Drives: 2017 camaro 2.0t
10 psi stock?
I have a mostly stock 2.0 camaro 6 spd. My only mods are a muffler delete and an injen intake. I believe that I read on this forum that stock our turbos put out close to 20 psi. Is that correct? I'm getting around 8psi with a spike to 10-11 for a second or 2.
acidronin is offline   Reply With Quote
Old 06-13-2018, 07:49 PM   #2
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
How are you measuring boost? 10 is half of stock.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 06-13-2018, 07:56 PM   #3
acidronin
I'm using torque pro to pull the data from the ecu. Will I get a different reading if I install a physical gauge?
Old 06-13-2018, 08:02 PM   #4
Beast-Y-Blue
Drives: Hyper Blue 2016 Camaro turbo
some gauge factor in barometric pressure... some dont. so look into that. nothing is wrong with your boost gauge or your car. i think barometric pressure is about 14 psi at sea level.
i use torque pro also i ll check which one to use.
i had the same reading and concern too until my tuner explain thag to me but i dont remember exsactly .
Beast-Y-Blue is offline   Reply With Quote
Old 06-13-2018, 08:29 PM   #5
Beast-Y-Blue
use intake manifold pressure.. that s the reading ur looking for
Old 06-13-2018, 08:34 PM   #6
acidronin
I'll give it a shot on the way to work in the morning. Thanks for your help.
Old 06-14-2018, 02:53 PM   #7
acidronin
I switched torque to pull from the maf instead of map and it hits 20 psi spot on. Thanks for your help.
Old 12-17-2018, 10:57 PM   #8
DTrammell
Drives: 2018 Camaro LT convertible
I was curious about the same thing - bone stock 2018 2.0L, both Torque (lite) and DashCommand (paid app) showed a max of around 10psi on the "boost" gauge. I'm reading around on dashxl.net forums for away to modify DashCommand to display the boost more accurately.
DTrammell is offline   Reply With Quote
Old 12-21-2018, 10:37 AM   #9
man0steel
Drives: 2016 2LT vert 2.0 R/S A8
Please don't shoot me for asking, but is the gauge in the dash not accurate or something?
man0steel is offline   Reply With Quote
Old 12-21-2018, 10:44 AM   #10
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
The gauge in the dash is only on the car if you got the convenience and technology package.
Old 12-21-2018, 11:13 AM   #11
man0steel
Old 01-08-2019, 11:43 PM   #12
irobles3680
Drives: 2017 2.0 Camaro LT
I use torque pro app too, and I think the intake manifold is better for boost psi, I get around 20psi mostly, sometime a around 22 but I have the jacfab boost o lator
irobles3680 is offline   Reply With Quote
Old 10-09-2019, 09:10 PM   #13
Vne182
Drives: 2019 Chevy Camaro LS
Thanks Everbody. If I choose to add a boost gauge is there a good line to tie into off the intake manifold? Everything looks like molded hard plastic lines.
Vne182 is offline   Reply With Quote
Old 10-09-2019, 09:12 PM   #14
Vne182
Is the Jacfab boost O' really a help for smoothing out boost pressure? Does it throw any CEL on the stock tune?
