12-21-2018, 12:35 PM | #15 |
Drives: ZL1 Join Date: Jul 2017
12-21-2018, 12:36 PM | #16 |
Drives: 2017 ZL1 A10 Join Date: Sep 2018
Cool video.
Thanks! |
12-21-2018, 03:20 PM | #17 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
The Guy driving the A10 ZL1 (the OP I believe) was definitely a better and more aggressive driver than the ZL1 1LE driver.
Good video though. Where in Texas is this track?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
12-21-2018, 03:22 PM | #18 |
What's even more impressive is the fact that, as I recall, the OP drives with one hand.
Kudos!
12-21-2018, 03:54 PM | #19 |
Drives: ZL1 1LE A10 Join Date: Mar 2015
That first shot in the beginning, the ZL1 1LE looks flatter in the turns. However that could be due to aggressive or lack of aggressive driving.
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
12-21-2018, 04:31 PM | #20 |
12-22-2018, 05:45 PM | #21 |
Drives: Camaro ZL1 A10 Join Date: Feb 2018
The Carbotech brake pads could make the difference with everything else equal but it's not so it's hard to judge but pads can make a noticeable difference. If anything it could show how important track pad are but then again it could be the drivers. Good to see a ZL
12-22-2018, 07:21 PM | #22 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Great video, the ZL1 1LE driver starts speeding up when you are in the lead. I bet both drivers learned a bunch. Thanks for sharing.
12-28-2018, 07:41 PM | #23 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Great driving RSFR, you really beat the ZL1 1LE with your ZL1 A10. even that you were short on tires compared to his wider track tires.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
12-28-2018, 08:37 PM | #24 | |
It has been my contention that the reason the 1LE seems so much faster than a ZL1 on track is mostly because of the difference in tires. Not because of the suspension, or aero, or whatever. I know this wasn't a perfect test to conclusively prove that, but I feel like it helps solidify my guesses. It was also a lot of fun to make the vid. |
12-29-2018, 12:53 PM | #25 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
While I have no doubt that the DSSV shocks on the ZLE are a little better performing when it comes to triple digit speed and track work, the MRC is no slouch either and from a car control standpoint, I believe the MRC can keep pace with the DSSV shocks, the difference is probably more of driver confidence from the faster acting DSSV that it give the driver. I am not sure about aero though and how much that plays into it, I have never driven a car with aero at speed to know what kind of effect it has. In the end as long as your suspension/bushing set can handle the increased grip from stickier tires, the biggest difference can be related to the avail. grip of tires, as it's the only thing in contact with the road.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
12-29-2018, 04:36 PM | #26 | |
I have aero coming and will see what kind of difference it makes. I have a pretty good baseline now around that track and can see what kind of difference parts make. Also shooting to install the GM solid rear bushing kit in the Spring sometime. |
12-29-2018, 05:29 PM | #27 | |
Have you swapped cars and driven both on track? Would love to get feedback on the MRC VS DSSV as far as composure and body/chassis control between the two.
Current:
12-29-2018, 08:18 PM | #28 |
I have not. I probably should, though.
