Old 03-29-2022, 01:33 PM   #1
ex-boxing champ
Drives: 2016 chevy camaro
Have any of you solved the coolant temperature gauge problem?
I am getting tired of having to unplug my car battery every week to get it reading again. It has no reading when it malfinctions. My air conditioner doesnt work when the coolant temperature gauge doesnt read. What part do I need to buy?
ex-boxing champ is offline   Reply With Quote
Old 03-29-2022, 03:01 PM   #2
snekk
snekk's Avatar
Drives: 2021 Camaro 1SS 1LE 10AT
I haven't had an issue like this with mine, are your coolant tank and coolant overflow at the proper levels?
2021 Camaro 1SS 1LE 10AT (Track)
  • Wild Cherry Tintcoat
  • Mobil1 ESP 0W-40 w/ ACdelco P64 filter
  • Castrol SRF Brake Fluid
  • Track Alignment (-2 Front, -1.5 Rear, 0.1 Toe)
2019 VW Golf R DSG (Daily/AutoX)
  • EQT Stage 1 ECU/TCU Tune
  • 350whp, 3.6s 0-60
snekk is offline   Reply With Quote
Old 03-29-2022, 03:41 PM   #3
DWR
DWR's Avatar
Drives: 2018 Camaro SS 1LE
First I’ve heard of someone having this issue…
Originally Posted by fastball View Post
Since 1967 kids all over America have bought the Camaro for the good old American way: loud and fun.
2007 Toyota Corolla S -- Traded
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled
2004 Silverado single cab 4.8l v-8 2wd -- Traded
2018 Camaro SS 1LE -- Current DD
DWR is offline   Reply With Quote
Old 03-29-2022, 05:47 PM   #4
Trochoidal
Drives: 2017 Camaro 2SS A8
This thread might offer you a solution.
https://www.camaro6.com/forums/showthread.php?t=535103
Old 03-29-2022, 05:52 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
These are new problems to me.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 03-29-2022, 06:21 PM   #6
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Had this problem intermittently happen 4 month after ownership.
Replaced the sensor: No bueno, phenomena continued.
Turned out to be the inside of the Connector of the coolant Temp sensor right near the TB / Intake hose.
Specifically, when looking inside the connector, there are 2 female "teeth".
One of these was open too wide and therefore an intermittent connection to the sensor's prongs . The solution: Simply use a pair of tweezers / long-nose plyer to carefully press these internal metal teeth together a little, in order to form a snug fit on the sensor's prongs.
I hope this helps.
Old 04-01-2022, 01:18 PM   #7
ex-boxing champ
I hope this helps.
Thanks for the tip. Is it easy to get at? Will I need any special tools and how long will it take me?
Old 04-01-2022, 01:19 PM   #8
ex-boxing champ
thank you for posting that. helps out alot
Old 04-01-2022, 03:20 PM   #9
Trochoidal
You’re welcome. Hopefully you get it fixed and it’s not too difficult as a DIY repair.
Old 04-01-2022, 08:53 PM   #10
Eldi Z
Very simple. Take off the plastic connector from the Coolant Temp sensor. Use a good torch-light to look into the inside of the connector and identify the small 2 female metal teeth-connectors.
Take a pair of tweezers / long nose plyers and carefully press each of these teeth together. Make sure the slot of these teeth is tight enough to snug fit on the sensors male prongs.
Re-connect the plastic connector onto the sensor.
Job Done.
Now see if this solved the problem.
If not, continue searching other reasons.
