03-13-2017, 11:38 AM | #1 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Clutch pedal
There is a little squeak coming from my clutch pedal when I let it out. It's just enough to where I can hear it and make it annoying. Anyone else have this issue or know if I can grease anything to make it stop?
03-13-2017, 11:43 AM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I'm having this same issues when it's cold out, curious to know if anyone has a solution.
Normally I just wait a few minutes and it goes away.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
03-13-2017, 12:17 PM | #3 |
Drives: 2015 blk 1 SS Join Date: May 2012
On my 12 LS it did that plus stuck to the floor when it was cold out,only at initial start up,dealer replaced clutch pedal,its a known problem
15 1 SS
03-13-2017, 12:28 PM | #4 |
It's not sticking yet and it happens when it's cold or warm. I noticed it before parking it for the winter and now it's getting warmer so I have brought it out and still notice it. It also happens if I let it out a certain way. If I let it out a little quicker it won't do it. But if I just ease it out, it will squeak a little
03-13-2017, 03:57 PM | #5 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Could be the spring riding in their nylon cups...when cold and they rotate could be cause? not sure but I do know this...I removed the spring(worthless) and I don't have any squeak...been driven here in MD daily unless road are crappy and until tomorrow that's been rare...temps have been in 20's..try it..nothin to lose and I believe it makes the peddle feel so much better...no numb over the hump peddle feel and get this...109k on stock drive train...with my valve train mods I can and will when ever the f'n tracks opens shift at 7k with ZERO probs....every time....peace out...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-14-2017, 03:43 AM | #6 |
when i installed my Ideal master i got a squeak. i put some grease on the socket that connects to the pedal. never squeaked again.
03-14-2017, 12:34 PM | #7 |
Drives: 2010 1SS RS M6 Join Date: Jan 2015
Your 2015 should be under warranty , I wouldn't even look at it, take it in
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
03-14-2017, 01:40 PM | #8 |
I was thinking about taking it in but if it was a simple fix then I could just do it. Plus it's not constantly so I didn't know if I took it in, my luck, it wouldn't squeak lol
03-14-2017, 02:04 PM | #9 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Similiar here, just with a new stock master cylinder. I used white lithium grease
03-14-2017, 10:29 PM | #10 |
ideal is just a ported new stock
03-14-2017, 10:32 PM | #11 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
fixes squeaks quick
