Old 05-21-2022, 11:18 AM   #1
Matt6951
Drives: None
M6 rear gears.
Who makes gears for this diff.. seems like some 4.11s or 4.30s would be perfect!
Matt6951 is offline   Reply With Quote
Old 05-21-2022, 12:02 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Unless something has changed recently, no one. The ring gear is welded instead of bolted to the carrier.
The only way I’ve read anyone changing ratio is a complete swap of the differential.
https://www.camaro6.com/forums/showthread.php?t=572705
https://www.camaro6.com/forums/showthread.php?t=520468
https://www.camaro6.com/forums/showthread.php?t=553854
Old 07-02-2022, 10:11 PM   #3
asthmamax11
asthmamax11's Avatar
PD supercharger makes it feel torquey like 4.30 gears would
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 07-03-2022, 06:56 PM   #4
NYblack1le
Drives: 2018 1SS 1LE
I believe rpm transmission has a gearset for the c7 ediff. I’d be interested to find out if the diffs are the same or close to it.
NYblack1le is offline   Reply With Quote
