07-20-2018, 06:31 PM | #1 |
Drives: '17 Summit White ZL1 Join Date: Jul 2017
Tony Mamo TB install problem
Hi Guys-
I just installed the TB. While I'm certainly not a wrench, it was pretty straightforward. Upon starting the car there's a considerably rough idle and the car dash shows "reduced power mode". Any ideas?? FWIW- no other mods to the engine other than green filter (which I installed two months ago).
Gregory -2017 Camaro ZL1
07-20-2018, 06:34 PM | #2 |
Drives: 2017 Camero ZL1 Join Date: Nov 2015
Added too much horsepower without a tune, put the stocker back on and it'll be good as new.
2017 ZL1 A10
Dyno/Quarter Mile/Dragy 9.71@141.2 MPH so far. 2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold. |
07-20-2018, 07:20 PM | #3 | |
Drives: 2018 ZL1 A10/2018 GT350R #JR603 Join Date: Jan 2017
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
07-20-2018, 07:35 PM | #4 |
Drives: Grandad's C2 L89 Join Date: May 2017
A negative cable disconnect before installation may have prevented a CEL/RPM.
If you physically touched the sensor end of the MAF that can code too. Try a battery disconnect. If that doesn't work, as hashtag mentioned you can clear the code with a OBD2 reader.
2018 ZL1 1LE sw/PDR
07-20-2018, 07:38 PM | #5 |
Thanks for the responses!!
I was getting a Throttle Actuator code that my reader wouldn't clear. Car sounded awful. I put the stock TB back on and cleared the CEL and it's smooth as before. Maybe I'll try again (this time disconnecting the negative battery cable) later.
07-20-2018, 07:54 PM | #6 |
Tony is a hands on guy and super helpful. You could get in touch with him if you can't resolve the issue.
2018 ZL1 1LE sw/PDR
07-20-2018, 07:57 PM | #7 |
Scientific negotiator
Drives: 2019 Grand Sport Join Date: Mar 2017
It sounds like a bad connection to the throttle body servo. Your description matches what would happen if you unplugged the TB and started the car. You sure it was seated all the way?
2019 Grand Sport M7
2018 ZL1 1LE 6MT 2017 SS 1LE 6MT . Matthew 25:40 ΜΟΛΩΝ ΛΑβΕ |
07-20-2018, 08:00 PM | #8 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
Going to have to return it and get a different one from Tony. Same thing happened to me. He said it was one of his more radically ported ones and not all cars like them. I could tell it wasn't brand new also and he tried it previously on another car before sending to me. Mine didn't like it either. Car ran like shit when started. Put old TB back on and it was fine. Tried resetting battery to do a relearn etc with Mamo TB and no better also. The new one he sent me works fine.
07-20-2018, 09:11 PM | #9 |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
Just ordered mine a couple of days ago. Hopefully, I don't encounter this problem
07-20-2018, 11:17 PM | #10 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
By chance did you unplug the MAF upon install? If so don’t. It’s best to leave it connected to the wires and just hanging until you put back together.
07-21-2018, 11:40 AM | #11 |
Drives: 2017 ZL1 Vert Arctic Blue Join Date: Mar 2017
Try a battery disconnect via the negative terminal in the trunk. Disconnect for a few minutes then reconnect.
07-21-2018, 03:03 PM | #12 |
I'm going to contact Tony and see if it's just a bad unit. Switching back to stock everything worked perfectly so I think that could be it.
You guys are great and thank you! I do love this car!
07-21-2018, 04:46 PM | #13 |
It's the throttle body he sent you 100%. He'll get you squared away though Tony's always been a stand up guy.
01-12-2019, 06:26 PM | #14 |
UPDATE**
Finally sent the Throttle body back to Tony and he IMMEDIATELY sent me a new one. Installed it and YES works great. Butt Dyno feels improvement. Sound is great too! Tony Mamo is SOLID!!
