![]() Drives: '23 LT1 Convertible (Auto) Join Date: Dec 2023
What are the downsides of installing wider wheels?
So I have a '23 Camaro LT1 and one of the things many recommend is upgrading the rear wheels to at least 275. I currently have the stock 245s all around and plan on swapping all the stock tires with Continental DWS06+.
I spoke to a family member and they say it's a bad idea because the car already handles enough, can wear out the engine and transmission more and people who suggest these say that people who do stuff like this do not plan on keeping their car for more than five years. Is there any truth to more engine wear? Doesn't seem to make sense to me considering that the LT1 has the exam same parts as the SS (which has 245 front and 275 rear) mechanically minus some coolers. |
Instagram: Sangstah
No, you will be fine adding wider wheels. You can run even wider if you wanted similar to a SS.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
#3 | |
2020 Shadow Gray 2SS
Whoever was telling you that nonsense doesn't know what they are talking about...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
![]() Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
Its true that you can wear out wheel bearings and some suspension parts if you put the wrong offset wheels on a vehicle.
Its not true if you utilize the factory sizes and offsets. You can just upgrade the rear wheels if you want to minimize cost. Or you can sell off all your current stuff and upgrade to the even wider sizes. I upgraded just the rear wheels/tires on mine to SS size. They work better than the 8.5s with 245s, but I think I would have been better off (traction wise) to just go with 1LE sizes and sell off my originals. If you want fuel economy, narrower is likely going to help that desire.
2022 CAMARO LT1 COUPE AT10
#5 | |
![]() Drives: 2023 Camaro LT1 M6 Join Date: Dec 2022
And as stated - A bunch of LT1 or SS owners have gone right up to the SS 1LE wheels/tire sizes. One other caution to keep in mind when going wider is that if you did increase the unsprung weight significantly (wheel + tire weight) you can somewhat decrease performance of acceleration and braking. Since I also have the LT1 with the smaller rear brakes I wanted to make sure I didn't overload them with wider wheels. Fortunately, when we upgrade LT1 and also go from non-run flats to normal high perf summer or all season tires you lower tire weight significantly that should offset if the wider wheels are somewhat heavier than stock (and of course more $$ can always get lighter weight wheels).
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers |
#6 | |
![]() Drives: 2016 1LT 'Vert Join Date: Feb 2022
If you took two identical LT1s and swapped 275’s on one of them, left the other on stock 245s, then proceeded to drive them side by side for 5 years and 60,000 miles. any difference in engine/transmission wear that you could discern is more likely attributable to other non-quantifable outside factors. Manufacturing variability being the primary one, which mostly boils down to the luck of the draw... Everyone’s build, driving environment and driving style is different. there is no way to to eliminate enough factors to be able to attribute powertrain wear directly back to tires. I’m sure most of us could either baby a Camaro for 150,000 miles or trash it in 12,000 regardless of the tires. |
#7 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Issue #1... Possible weight increase.
Issue #2... Will have you spending hours researching tire. Issue #3... Bigger tires can be more expensive. Issue #4... More traction ![]() Issue #5... More traction will have you adding HP. Issue #6... Possibly too much male attention. Issue #7... You may stop doing other things you use to like, so you can touch your new larger tires all the time... You have been warned. Note: Mine are 19x11 up front and 19x12 out back.
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 770rwhp 815rwtq @E55 13.5psi |
#8 |
Yo appreciate all you have been sharing everyone. The 245s definitely aren't enough. Kind of debating if I should go higher than 275 and of course swap out the fronts too depending on how much wider I were to go.
What are your thoughts on the speedometer being off? Any way to fix that without voiding your warranty? |
#9 | |
If you want the great looking 1LE style wheels, the MRR017 wheel in Gun Metal Gray is a great choice at a reasonable price... Here is my before and after on my 2SS... Before: ![]() After (with MRR017 1LE Replica Wheels): ![]()
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... Last edited by 2SS Capt; 12-14-2023 at 10:59 PM. |
#10 | |
#11 | |
https://www.camaro6.com/forums/showthread.php?t=619771
#12 |
![]() Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
One downside is going to be wet pavement performance. My 2LT with stock tire sizes was my daily driver and was terrible in the rain and required slowing down significantly and being extra vigilant. With my ZL1 I do not drive it in the rain, but I don’t use it as a daily. The problem is all things being equal, a wider tire is not going to displace water as fast as a narrower one and when it can no longer do so you hydroplane. Tread design is a huge factor in this as well, so some tires are going to do better in this regard. Tire selection is going to be a much bigger consideration if you plan on driving it in all weather conditions.
#13 | |
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 12-15-2023 at 08:28 AM. |
#14 | |
