Old 01-29-2024, 06:21 PM   #1
Laidoffsick
Laidoffsick's Avatar
Drives: Camaro ZL1
Where Do These Plastic Pieces Go?
I've had these things laying in the garage for over 2 years now. They were in the trunk when I picked up my '22 ZL1. For the life of me I can't line up any holes under the front of the car where they might go.
Pix will help greatly..
Laidoffsick is offline   Reply With Quote
Old 01-29-2024, 06:44 PM   #2
DangerZL1
Drives: 2023 Black ZL1 Auto
They go under the front bumper mounted to the black plastic shielding. Your dealer should have installed them during PDI.
Old 01-29-2024, 06:45 PM   #3
bootss
Drives: 2021 ZL1 1LE with PDR
They look like are part of the brake cooling ductwork. The rounded ones are the tire deflector, I forget what the others are.
bootss is offline   Reply With Quote
Old 01-29-2024, 07:35 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
They attach in front of the front wheels on each side, with the rubber/plastic strip, going across the front of each front corner. They basically funnel air on to the tire.
Old 01-29-2024, 07:39 PM   #5
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1969 Cessna Skylane
I remember someone saying two of the pieces are just for the track. Not sure if that's true or not or why.
dfwcowboy is offline   Reply With Quote
Old 01-29-2024, 08:35 PM   #6
Laidoffsick
Drives: Camaro ZL1
What about the 2 flat straight pieces?
Old 01-29-2024, 08:53 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
They go across the front edge on each side if you look at the third picture
Old 01-29-2024, 09:06 PM   #8
Laidoffsick
Drives: Camaro ZL1
Thank you
Old 01-30-2024, 02:03 AM   #9
The Zebra
Drives: '24 ZL1 A10, '70 Olds 442 W-30
Those two flat pieces are intended for track use only. It won't hurt anything to leave them on for street use, though.
The Zebra is offline   Reply With Quote
Old 01-30-2024, 06:18 AM   #10
Z OH 6
Drives: 2021 Red Hot ZL1
Mine were installed by the dealer.
Z OH 6 is online now   Reply With Quote
Old 01-30-2024, 07:49 AM   #11
DangerZL1
My dealer left the two flat pieces off too. I installed them since they offer some protection for the underside of the front bumper.
Old 01-30-2024, 08:06 AM   #12
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
Usually, these are installed by the dealer after the car is taken delivery of as they will often scrape being unloaded if installed due to the incline on those trailers. That's something to keep in mind if the car has to be trailered or towed moving forward. This is also why many cars don't get the spring blocks (orange blocks) removed because the car sits higher in front.
I do recommend installing them however if you are planning to track/race the car for any reason. It does help with the aero on keeping the car planted. It's not a must have item but it's a very painless install if you do have to do it.
Old 01-30-2024, 02:35 PM   #13
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
here's the sheet that should have come with them
Old 01-30-2024, 07:17 PM   #14
Broooster
Drives: Sharkskin Metallic ZL1
I really like this forum. I asked this exact same question last year in a Facebook group and got "RTFM' for an answer. Go figure. Anyway, this is a great place to learn.
Broooster is online now   Reply With Quote
