02-04-2024, 04:25 AM | #1 |
Drives: 2016 z06 Join Date: Sep 2020
2023 trunk not opening
it does this from time to time where i can hear the latch but it does not pop open and it stays closed-i see where the etr may be the problem has anyone else had this problem and what is the fix?
TIA Mark |
02-04-2024, 06:25 AM | #2 |
Drives: 2023 Chevy Camaro ZL1 Join Date: Mar 2023
I had the same problem. In my case it was because I didnt open the trunk very often and the weather seal around the trunk opening was sticking to the trunk lid. I cleaned the seal and the area on the trunk lid it makes contact with and applied a ceramic detail spray to the same areas and no problems since. My car is also a 2023.
02-04-2024, 06:29 AM | #3 |
Drives: 2023 Chevy Camaro 2LT V6 6MT Join Date: Sep 2023
My 2023 has done this a few times. I hear the release but trunk does not open. I tried lifting it but couldn’t. Waited a min and hit the button again and it pops up. Odd.
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
02-04-2024, 07:33 AM | #4 |
The "poppers" may need a little adjustment and/or the latch might be binding a bit. When the trunk won't open, people tend to do two things: first, push down on it and simultaneously press the button until it opens, then adjust the poppers slightly; and second, lubricate the latch with lithium grease. See these threads below.
https://www.camaro6.com/forums/showthread.php?t=539602 https://www.camaro6.com/forums/showthread.php?t=544455 https://www.camaro6.com/forums/showthread.php?t=471732
02-04-2024, 07:52 AM | #5 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I had the same problem with my 2023. I tried lubing the weatherstripping with gummi pledge and it didn’t help. I greased the inside of the latch striker area and it hasn’t stuck shut since.
02-04-2024, 08:15 AM | #6 |
My 2017 does that every once in a while when I use the trunk release above the license plate. I hardly ever use the the button on the door panel.
02-04-2024, 08:49 AM | #7 |
Low battery was the cause when this happened
'20 ZL1 1LE A10,
02-04-2024, 11:14 AM | #8 |
Drives: None Join Date: Feb 2016
A squirt of lithium grease fixed mine. Also 2023.
Sent from my iPhone using Tapatalk |
02-04-2024, 12:27 PM | #9 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
I believe there was a recent repair procedure released by GM. It was for the 23 and 24 models. It had to do with the emergency release in the trunk.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
02-04-2024, 06:18 PM | #10 |
My 23 also does this and will try the lithium grease.
02-04-2024, 07:30 PM | #11 | |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
Jim G |
02-05-2024, 11:02 AM | #12 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
my 19 does this and it's because it's shut all the way, but it's not.... When this happens, I just push down on the trunk to lock it again and it pops right up the next time. It's weird. But since I'm in Thailand, I'm not spending time on this until all else is done with my project.
