10-08-2023, 06:38 PM | #1 |
Drives: 2018 Chevy Camaro ss 1LE Join Date: May 2020
ZL1 front Brakes on my 1LE
Hi Does anyone know if I buy a ZL1 front brake package, can I use them on my SS1LE.
I know the ZL1 has a bigger diameter rotor. Someone is selling a very low mileage zL1 brake set up. I just want to make sure, it is a direct bolt in. With no modifications Thank you Last edited by CC2018SS1LE; 10-08-2023 at 07:28 PM. |
10-08-2023, 07:01 PM | #2 |
Always thought the SS/1LE already has the same 6-piston Brembo that the ZL1’s did…?!?
10-08-2023, 07:59 PM | #3 |
10-08-2023, 08:14 PM | #4 |
Interesting. Learn something new everyday. Thanks!
10-08-2023, 08:16 PM | #5 | |
The pads are also very different, check out this pic, ZL1 on the left and SS 1LE on the right (courtesy our fellow member L78toLT1). The delta isn't as dramatic as the picture suggests, and these SS 1LE pads are actually preeetty big, too, but the ZL1 pads do have a wider sweep area and less material cut off along the inner diameter of the rotor. Finally, the calipers are also slightly different, of course, although those are the closest of the three.
10-08-2023, 08:26 PM | #6 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Yes, the front caliper and rotor are different.
The rear brakes are not the same UNLESS the SS 1LE and ZL1/ZLE have the new for '22 & up BCD copper free brake package. ZL1 brakes have been done on an SS 1LE before here on the forum. Here is one member's info: https://www.camaro6.com/forums/showthread.php?t=481117 Great way to add more heat capacity(mass) on an SS 1LE.
10-08-2023, 08:29 PM | #7 |
Drives: 15 RH Z/28, 23 RB2SS1LE, 23LT1VOM Join Date: Dec 2012
Aren't the RPO BCD fronts the same as on the Blackwing?
10-08-2023, 08:33 PM | #8 | |
10-08-2023, 08:35 PM | #9 | |
Thx |
10-08-2023, 08:41 PM | #10 | |
10-08-2023, 10:18 PM | #11 | |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
A nice summary of differences is here: https://www.camaro6.com/forums/showthread.php?t=526596 |
10-09-2023, 10:42 AM | #12 |
Look deeper. Starts on page 3. He gives track use feedback.
10-09-2023, 10:44 AM | #13 |
Yes and no.....Different part #s but the overall idea is the same. Not sure if the rotor hat offset is the same. The Caddy rotors have a different part #.
