02-10-2017, 10:04 AM | #141 | |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
I'd personally still probably just upgrade at least the less expensive of the fuel pumps as well though. |
02-10-2017, 10:11 AM | #142 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
02-10-2017, 10:19 AM | #143 | |
FASTER!
Newer meth systems also have some electronics built in that can warn the driver with a LED or activate solenoids etc. You just have to make sure you've installed everything properly and tested it. I've got about 3 weeks of experience with water/meth injection with the 4Runner and so far I'm very pleased. It was my only choice there as I mentioned though. With the Camaro we have other options, just depends on what solution the owner prefers. I use -20 washer fluid with a 12oz bottle of Heet added. You HAVE to use the plain jane blue washer fluid with no additives or detergents. You'll know you have the right stuff if you shake the bottle and the suds immediately disperse. The MSDS sheet on -20 says it's 30% methanol. If you're lucky enough to have -35 in your area it's closer to 45%. Heet is 99% methanol. You can mix your own if you can find pure methanol in you're area. It's mixed by WEIGHT not volume. A 50/50 mix by weight is the preferred mix. I did the math last night and -20 washer fluid with 12oz of Heet added comes out to 35% methanol. It's cheap and working for my application so that's where I'll stay. I found a race shop that sells 5gallon pails of methanol for about $36, but you have to be conscious about storage as it will absorb moisture and is very flammable as well. |
02-10-2017, 10:49 AM | #144 | |||
Drives: Many C7's Join Date: Apr 2014
I have had a customer call me that was out racing and goes "dude the tunes got something wrong with it, it just laid over and won't restart" I drive out there, only to find.... he had run it out of GAS! Think about that for a moment, he was out racing beating on it with a tank super crazy low, to the point of running it dead empty during a WOT pull. Imagine how lucky he is to even have a motor at this point. LOL. My rule of thumb, never push on the "loud pedal" with less then 1/4 tank. Quote:
Every tuner has his ways of doing things. I don't care to get into an internet debate on whats the best, or wrong or right. I know what works for me, been using it for 15 years now, all good. Quote:
You will notice. LOL. Now if a person stays in the throttle....well then, they should have the car removed from them, and start a new hobby like stamp collecting. A person always has to remember to "respect the power" and understand how it feels when everything is perfect, to know that when something doesn't "feel right"... it usually means it isn't. Thankfully thats rare these days, but you never know. Even "bad gas" does happen. (way way way more often then "bad meth" lol) |
02-10-2017, 11:08 AM | #145 |
Hahahaha. I think that depends on what form of meth you're talking about. Sorry way off topic!
02-10-2017, 02:05 PM | #146 |
Drives: 2016 2SS Join Date: Nov 2011
I cook meth every day...prank call, prank call.
Who Dares...Wins |
02-10-2017, 02:08 PM | #147 |
02-10-2017, 04:56 PM | #148 |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
The only alcohol I want in my Camaro is a case of wine in the trunk!
02-13-2017, 09:22 AM | #149 |
02-26-2017, 10:30 AM | #150 |
Drives: Audi S6 V8TT, Volvos XC60 & S60R Join Date: Feb 2016
One subject that was not covered here is the point of injection for both PD and Centri systems.
For the Centri it is most likely placed after the IC, is it on the charge pipe or the intake manifold? But for PDīs where is the right spot, before the SC on the intake pipe? Doesn't that bring possible corrosion on the SC head unit? Also, is the T.B. subject to corrosion from the Meth? |
02-27-2017, 12:04 PM | #151 | |
Drives: 2016 Camaro SS M6 w/ NPP Join Date: Jun 2016
The meth being sprayed into a PD blower has been a topic of discussion for a long time. When I worked at Magnuson, I had seen several instances where the abradable coating on the rotors was cleaned off by the meth. When that happens, it can affect the effectiveness of the rotors. As far as the TB, I would think the meth would keep it cleaner....
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system, Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion 28"x10.5" MT ET Drag 28"x4.5" M&H fronts PB: 9.569 @ 151.05 |
02-27-2017, 12:43 PM | #152 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
02-27-2017, 01:12 PM | #153 | |
Funny, there are MANY people that swear that doesn't happen. Yet, I have seen it happen with my own eyes. Glads to see someone "in the know" says it can happen |
02-27-2017, 04:59 PM | #154 |
Heres one thread that still exists. http://www.corvetteforum.com/forums/...with-meth.html
From what I understood, Jerry Magnuson was strongly against it. Perhaps the new owners changed the coating and made it withstand more? #IdunnoImjustagirl
