12-14-2020, 12:12 PM | #85 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
One last thing
Doubtful, but I'll say it's the last thing.
I suspect the reason for crimping the washer is for ease of assembly. It is a royal PIA to remove. So, you'll have to make a choice to reuse the washers as is or plan to get the old one off. I used a pair of side cutters and then twisted with needle nose pliers to remove. Everything is slippery from the brake fluid so it takes some time. Keep an eye on the amount of brake fluid in the reservoir so you don't get air in the system.
12-17-2020, 05:53 AM | #86 | |
Drives: 1LEs Join Date: May 2009
12-24-2020, 09:37 AM | #87 |
I received my 23242510 pistons. Like you said very poorly packaged. Basically loose in a plastic bag sitting on a plastic tray and each bag had had 1 piston that had came out of the protective wrap. One of the pistons has a nick in it. Does this make it bad?
12-24-2020, 12:25 PM | #88 |
Measure to top of pressure seal in caliper. If the nick is above it, it won’t do anything. If at or below, I’d smooth it out. Might need to smooth it anyways if it catches on the bore.
12-24-2020, 07:18 PM | #89 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Will the vented insert pull out of the piston?
12-24-2020, 07:53 PM | #90 |
I pulled on one and it didn't move.
12-26-2020, 12:46 PM | #91 | |
Geoff
IMO if the damage is where the seal can ride, don't use it. If above or below, no problem to knock off the high spot so it doesn't catch or scratch the bore.
01-10-2021, 01:03 PM | #92 |
Geoff
C&R Oil Cooler
Thx to travislambert for working with C&R getting this done. LSA has a thread here:
https://www.camaro6.com/forums/showthread.php?t=583742 Post 14 has the temp data he gathered, before and after. It was a straight forward install. The fit and construction of the C&R bits were superb. I used the filling adapter from DMS to refill the SC system. I made a fused jumper to power the SC pump so the air would 'burp' out. A rule of thumb, if you hear the pump running, there is still air in the system.
02-02-2021, 05:34 PM | #93 |
Geoff
Fire Extinguisher Mount
I put in the Brey-Krause fire extinguisher mount because an FE is required to participate in The BBORR. I chose not use their hardware & used some nuts/bolts that I had.
DIY here https://www.camaro6.com/forums/showthread.php?t=587907 The FE is ordered and I'll mount it when it comes in. Straight forward and something I hope to never use.
02-03-2021, 03:13 PM | #94 |
Geoff
I found this while looking at TSBs. Drain and fill is the recommendation for transmission service.
TSB 040601029J, dated 28Feb2020
02-03-2021, 11:49 PM | #95 |
Drives: Grandad's C2 L89 Join Date: May 2017
Good find.
Thanks for posting Geoff.
2018 ZL1 1LE sw/PDR
02-04-2021, 08:02 AM | #96 |
Geoff
You’re welcome
It’s across all GM vehicles, automatic and manual transmissions. I’m glad I found it, I’d planned to do a full flush at the next service.
02-04-2021, 03:09 PM | #97 |
Drives: Corvette GS w Z07 Package Join Date: Mar 2019
Nice Thread and very informative. What I see, the most important that I learnt is that you track you car very frequently you did not touched the suspension, just improving the reliability of the car. The car is perfect from factory, there is not need of DSSV dampers o DSC controller unless you run at a very competitive level.
Do you have in mind any aero modification? Keep posting good ideas
MY02 S2000 > MY11STI > MY01 E46 M3 > MY05 S2000 > MY06 911 C2S > MY88 944 TURBO S > MY17 STI > MY17 SS 1LE > C7 GS w/ ZO7 package > MY18 ZL1
02-05-2021, 09:52 AM | #98 | |
Geoff
You've highlighted a couple failings with this thread. I had not posted some mods..... Sway bars Aero
