03-29-2018, 08:34 PM | #1 |
ZFR turbo swap
There were some threads on this but wasn't going to dig them up.
Stock turbo to ZFR turbo Would have took me about 5 hours, but I had an issue that delayed me. ZZP already had the replacement bolt in the mail before I broke the aluminum one that came with the kit. I had one of the originals. ZZP now supplies the steel bolt before purchase. Otherwise it was a smooth install. It spools quick, temps are good, whistles nicely, and simply sounds great. Also the outlet tube only required a 2" to 2.5" coupler to mate with the mishimoto hot side aluminum pipe . |
03-29-2018, 09:01 PM | #2 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Got any wheel shots of that turbo? It sure is pretty!!
03-29-2018, 09:34 PM | #3 |
03-29-2018, 09:35 PM | #4 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
Sick.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
03-29-2018, 09:37 PM | #5 |
I have to figure out youtube.. I got a video of it glowing during a dyno run
03-29-2018, 09:38 PM | #6 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
they heat up crazy fast.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
03-29-2018, 10:31 PM | #7 |
03-30-2018, 02:47 AM | #8 | |
03-30-2018, 07:56 AM | #9 |
603 Camaros
He's doing a conservative tuning process with ZZP. So low numbers until they decide what everyone wants to do.
03-30-2018, 08:03 AM | #10 | |
05-09-2018, 01:48 PM | #11 |
Drives: 2019 6.2L V8 SS Join Date: Feb 2018
Not to resurrect a mostly dead thread... but directed at StPeteHyper - are you guys fearing going lean with the ZFR, stock fueling system, and 93 gas combo? Are most things seemingly under control without any concerns still over a month later?
Is this your daily driver, and if so - do you feel like driveability has gone down at all to this end post installation and tuning? I'd definitely want to push into the 370-380 range to hit stock SS rwhp figures. Just looking for some first-hand experience since you're the first person around here I see regularly posting and running one.
05-10-2018, 03:58 PM | #12 | |
- It is my daily and hell no, drivability is way up.. you would have to get over 500hp to start considering it not being a daily. People daily 600hp SS - You are pushing your luck going over 350hp/400tq on a stock block. you also don't need SS numbers to beat a SS with the weight difference. to be honest it is hard for me to compare. I went from stock tune to ZFR turbo tune. If I had the stock turbo tuned, I am not sure how much of a difference it would have been. I like the sounds and punch of it tho. A lot of people are 310-320 hp on stock turbos and run good track numbers. I haven't made it to the track yet. |
05-10-2018, 06:29 PM | #13 | |
05-23-2018, 11:00 AM | #14 |
Drives: 2017 Cadillac ATS Join Date: Sep 2017
Any updates on this?
