Old 03-31-2017, 10:20 AM   #1
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
Grinding noise when slowing...
I had 5th gen ZL1 wheels installed (kept aftermarket tires from my Vossens). Had new red Monster lugs installed too.
I also had ceramic pads installed about 6 weeks back.
I am getting a rough grinding sound when coming to a stop.
I checked for tire rub, have enough caliper clearance. Any other things to check?
ajp is offline   Reply With Quote
Old 03-31-2017, 10:33 AM   #2
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
If there is no noise when driving, then it is the brakes for sure. It might just the new ceramic pads breaking in
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 03-31-2017, 11:08 AM   #3
TJay74
Did you go thru the pad bedding process on the new pads?
Old 03-31-2017, 02:58 PM   #4
ajp
ajp's Avatar
I did go through the bedding process, not sure if I did it right.
A few more observations:
1) I hear the noise when slowing without braking.
2) I can kinda feel the grinding through the steering wheel, though that may be my imagination.
Old 04-01-2017, 08:11 AM   #5
TJay74
I would get the car up on jackstands on all 4 wheels and spin each wheel by hand to see if you can hear the noise if it was me.
Old 04-02-2017, 08:23 PM   #6
Sunsnare98
Drives: 2017 camaro ss
It could be tire noise.
Sunsnare98 is offline   Reply With Quote
Old 04-06-2017, 11:25 AM   #7
ajp
ajp's Avatar
Dealer checked it out today, said its the ceramics. Said they make a noise when slowing even when not actively applying brakes.
Old 04-06-2017, 11:28 AM   #8
Sub
Sub's Avatar
Drives: 2017 ZL1
Look for gouging on the rotors - inside and out. a small line will indicate a rock or something may be stuck in there - this happened to me once.
You can also do a hard stop or two. If its a small rock chip it'll probably come loose/break off.
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 04-06-2017, 11:43 AM   #9
ajp
ajp's Avatar
Dealer checked, said the rear right had a rock at one time, but didnt see anything.
Old 04-06-2017, 07:30 PM   #10
Sub
Sub's Avatar
Drives: 2017 ZL1
probably a little shard left in there. just do some hard braking action.
