05-15-2021, 08:18 AM | #1 |
Drives: 2018 Camaro ZL1 A10 HBM Join Date: Mar 2019
Headers Installed w/catted connection - Extremely Loud!
I had the Texas Speed headers with catted connection pipes installed (AWE Touring exhaust) and now my car is way too loud. I like loud cars but this thing is ridiculous. I don’t even enjoy stomping on it anymore. I know some of you will scoff at this, but I’m looking for suggestions to tone it down. Are there good options for resonators or a different set of cats to replace the ones Texas Speed provided? I’m actually curious if they accidentally gave me the off road version instead because I have a hard time believing this is normal for this setup. I also noticed a much more pronounced gas smell which I thought was only a side effect of a cat delete.
Garage Baby 1: 2018 Camaro ZL1 A10 HBM w/Rotofab CAI, Tony Mamo Ported TB, AWE Touring Non-Resonated Exhaust, Diode Dynamics Sidemarkers, Suntek PPF, Feynlab Ceramic Coating Garage Baby 2: 2017 Dodge Challenger R/T Scat Pack 392 Shaker A8 Green Go |
05-15-2021, 08:23 AM | #2 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Try putting the OE Suitcase back on. I just traded in a 2SS with Npp in for a ZL1 and the ZL1 is MUCH louder even with the NPP. I can't imagine what headers do to these cars for sound.
2012 Yukon XL Denali w/ 6.2 AWD |
05-15-2021, 08:26 AM | #3 |
Drives: 2010 Camaro 2ss procharged Join Date: Apr 2015
To loud
I installed borla resonators before my x pipe Really helped with noise. I don’t know if they still make them or not. But I am catless also. Hope that helps.
05-15-2021, 09:04 AM | #4 | |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
There are some aftermarket NPP or try to go back to stock NPP. How was the install of the TS headers? Sent from my moto g(7) power using Tapatalk
05-15-2021, 09:17 AM | #5 |
Drives: 2017 ZL1 Join Date: Apr 2020
Buy a prius ? Lol just kidding. Enjoy the sound of hp
2017 ZL1 M6 Silver Ice Metallic
05-15-2021, 09:21 AM | #6 |
Looks like I should have searched the forums first. A lot of people have had similar issues. I think I’m going to try the Magnaflow muffler solution (https://www.magnaflow.com/products/1...rmance-muffler) to see if that helps. It’s relatively inexpensive so if I don’t like it I can try something else.
05-15-2021, 09:39 AM | #7 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I would first ensure you do have cats in place although it is quite normal for these cars to get quite loud with headers. If you do still have cats and it's too loud for you, you can replace the AWE exhaust with the stock exhaust or buy an aftermarket exhaust with valves such as the Borla S-Type. Personally, I'm fine with the AWE resonated touring exhaust, headers and high flow cats but I did install a set of Vibrant 1795 resonators in place of the AWE resonators, it helped smooth the sound some but of course it's still quite loud.
05-15-2021, 09:40 AM | #8 | |
05-15-2021, 10:16 AM | #9 |
Call AWE and get the resonated section for your exhaust.
2016 NFG 1SS A8
05-15-2021, 10:40 AM | #10 |
Drives: 2016 Camaro SS Join Date: Jan 2019
It's all subjective but I had Kooks catless headers, Borla mid/x-pipes (resonated), and Borla S-Type mufflers and thought it was too loud. I added the Magnaflow muffler and it quieted it a lot, kind of too much. I ended up ditching the Magnaflow and swapping the S-Type for a stock suitcase. Now it's loud when floored but very manageable otherwise, albeit does have a higher pitch to it. I'd checkout KingLT1's idea first before cutting up your exhaust though a resonator probably won't do as much as you'd like for sound level.
I'm sure you've seen this: https://www.camaro6.com/forums/showthread.php?t=576096
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc... |
05-15-2021, 12:31 PM | #11 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Which AWE system do you have? AWE does make resonators, which could tone it down.
05-15-2021, 12:49 PM | #12 | |
Edit: I did the additional Magnaflow muffler too and it really helped.
05-15-2021, 02:11 PM | #13 |
Have CSP 2” headers with off-road pipe to NPP exhaust. It’s the best of both worlds!
CSP 755 Package. 2” headers, Kong ported blower, NW103mm TB, RF Big Gulp, Mighty Mouse catch can.
630rwhp/660rwtq. |
05-15-2021, 07:53 PM | #14 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
One member on here suggested vibrant 1795 resonators. Has your same setup. Said the awe resonators didn’t quite get the job done
https://www.camaro6.com/forums/showthread.php?t=591116 Last edited by Cleancoupe; 05-15-2021 at 07:58 PM. Reason: Added link |
