Old 08-02-2022, 02:30 PM   #1
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Part # on line??
I have to replace the outside line on the passenger side. I have no idea how the line got bent but it is. I can see and read the tag on the line but when I search the gm parts site I can’t find it in any area. I want to order the line but can’t find it without going to the dealership.
Maybe that tag just doesn’t reveal all the numbers?
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 08-02-2022, 02:39 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
What is that line? I don’t recognize it from this picture?
Old 08-02-2022, 02:49 PM   #3
BlackbeastSS2
I followed the line back to the rear diff, so I am thinking it’s the Differential Cooling line on the 1LE.
Old 08-02-2022, 03:03 PM   #4
Trochoidal
Ah ok. I’ll look for it too. On the A8 cars I recall this line needs to get unbolted from the case to get to the fill plug and that’s also on the passenger side.
I’ll keep in mind this is for your 1LE.
Edit: So it looks like this is more commonly referenced as a transmission cooler pipe. I didn’t find anything relating to differential cooling pipe.
From Motor Trend article(you most likely know this but they reference transmission cooler):
“ Differential cooling is standard on the SS. It uses an oil-to-oil cooler that runs transmission fluid through a heat exchanger that's submerged in the differential oil.”
Also I found nothing on 2019 but there are a bunch of lines listed for 2022. All of this may be worthless.
Maybe one of these is your line.
https://www.summitracing.com/search/...t/model/camaro
Last edited by Trochoidal; 08-02-2022 at 03:49 PM. Reason: Updated with more information
Old 08-03-2022, 04:57 PM   #5
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
tough to know exactly what line is in the picture.
look at these drawings to see what line you are wanting.
Old 08-03-2022, 07:08 PM   #6
Trochoidal
Can you post the tables with their corresponding part numbers and descriptions to accompany these PDF’s?
Old 08-04-2022, 06:53 AM   #7
h018871
Geoff
h018871's Avatar
Unfortunately there is not a pn list corresponding to the numbers on the drawings.
If the OP tells me the number and on which sheet, I can get the part #.
Old 08-05-2022, 03:11 PM   #8
BlackbeastSS2
I am still looking for the part. Thanks for all the input. Not sure what u mean by number and which sheet.
Old 08-05-2022, 06:48 PM   #9
discgolf01
Drives: 2018 ZL1 Convertible M6
Those 4 numbers on the tag are most likely the last 4 numbers of an 8 digit part number, used by the factory to ensure the correct PN of pipe bundle goes on the car. I'm guessing somewhere on that tag is the 8 digit PN, but in much smaller font.
You could also try scanning the bar code with your cell phone and appropriate app.
discgolf01 is offline   Reply With Quote
Old 08-06-2022, 08:31 AM   #10
h018871
Geoff
h018871's Avatar
No worries
The pdfs are called cooling lines 1 & 2, that is the sheet number
Each cooling line in the pdf have a little box with a line to it that identifies the line so I can get you the part number to order. Easy peasy
Old 08-06-2022, 09:25 AM   #11
BlackbeastSS2
No worries
Going to Jack up car in a few hours, take the label off to hopefully see the full number like someone else suggested. It’s the outer line of the two on the passenger side.
Old 08-06-2022, 11:10 AM   #12
BlackbeastSS2
No worries
Took the tag off and got the smaller number but still can’t find the part.
# 66704133
Old 08-06-2022, 12:44 PM   #13
h018871
Geoff
h018871's Avatar
Is it line # 1 of this drawing? If so pn 84894912, includes both lines and #s 2,7,18,19&21
If you look closely, you can see the tag in the drawing near the bracket, where your tag was.
It runs from the passenger side of the trans cooler back towards the differential
Old 08-06-2022, 12:52 PM   #14
BlackbeastSS2
Thanks so much, much appreciated. I just looked up the part number on internet and that’s the one. Your golden buddy.
