Old 04-17-2017, 07:14 PM   #15
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Mods why the thread swap? A lot of the information in this thread is going to pertain specifically to the OEM 1LE tires, NOT any other Camaro models.
seanblurr is offline   Reply With Quote
Old 04-17-2017, 07:17 PM   #16
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Really? Just like only square set ups on a 1LE I guess?
20x10 and 20x11 fit on all Camaros. Goodyears work on all Camaros
Old 04-17-2017, 07:18 PM   #17
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by TrackClub View Post
Where do u buy APEX wheels from pls?
BTW Pirelli also carries slicks in DH (dry/hard) compound in 19 inch size 295/680 which is about a 33 aspect ratio I think.
I bought directly from their website:
https://www.apexraceparts.com/wheels/all-wheels.html
glamcem is offline   Reply With Quote
Old 04-17-2017, 07:27 PM   #18
glamcem
glamcem's Avatar
That might be true. However, don't forget, 1LE suspension tuning and itself is very different so one that works for the 1LE may or may not work for the regular SS or SS with MRCs, since the suspension tuning is different.
With the softer track / R comp tires, the ideal sizes will also be different since the spring rates, sway bars and bushings are different with softer and wider tires. It is very common to see suspension flex and the rubbing inside the fender wheels is somewhat easierthan the stiffer 1LE tuning and suspension.
B/c of the above reasons it is hard to say if this should be in different section than the 1LE section
Old 04-17-2017, 07:49 PM   #19
TrackClub
TrackClub's Avatar
please...happy for EVERYBODY to take advantage of this info, but it is specific to 1LE wheels, tires, suspension, etc. ONLY 1LE option provides for 10 and 11 inch rims.
I will delete this info as I would be concerned by other owners potentially mis-using it for non specific applications and it would be a SHAME if this forum didn't allow us to discuss 1le specifics after creating a specific forum place for the car. PLEASE move it back. thank you!
Old 04-17-2017, 08:41 PM   #20
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
WTF, moderators just bored looking to frustrate users?
Provoste is offline   Reply With Quote
Old 04-17-2017, 08:52 PM   #21
TrackClub
TrackClub's Avatar
OMG it ended up buried in "wheels and tires - sponsored by the Tire Rack"...WTF is right. What's next? Brake pad disappears to another sponsor thread? THIS SUCKS!!!
Old 04-17-2017, 09:15 PM   #22
TrackClub
TrackClub's Avatar
well, motrospors ranch vid thread got moved out as well even tho 1le has a STICKY dedicated to this very subject. strange things are happening.....
Old 04-17-2017, 10:20 PM   #23
TrackClub
TrackClub's Avatar
Glamcem: what are the specs of the wheels u bought? These are a no brainer and size wise open up the biggest selection of tires for the 1le.
BTW: to all - I've updated the OP with wheel/tire info. Copy it if you like., as I am debating deleting it all now that the thread has been moved.
Old 04-18-2017, 12:30 PM   #24
glamcem
glamcem's Avatar
http://www.camaro6.com/forums/showthread.php?t=486305
Here is all the details about the wheels and fitment, read it and let me know if you have any questions
Old 04-18-2017, 12:40 PM   #25
TrackClub
TrackClub's Avatar
Thanks! Would it be possible for you to summarize it in a short note re offsets, spacers, other considerations so I could up load it to the OP for the community to see without going thru 8 pages and making notes - and maybe getting it wrong lol
Old 04-18-2017, 12:58 PM   #26
glamcem
glamcem's Avatar
19X10.5" ET22 APEX PS-7 WHEEL (front)
19X11" ET25 APEX PS-7 WHEEL (rear)
Since I have the 10.5" instead of 10", 3mm spacer is required for street alignment and 5mm and some grinding for the track alignment.
This may not be the case for the 10" as it has additional 3mm clearance
Old 04-18-2017, 01:01 PM   #27
TrackClub
TrackClub's Avatar
Awesome thx will move it up, just one more question: how much camber do u get with those on?
Old 04-18-2017, 02:22 PM   #28
glamcem
glamcem's Avatar
sure. Currently I am running -2.2 front and -1.6 camber in the rear. I will see if I can get -2.4 or -2.5 without any issues up front and will have them adjust the rears for -1.8 . I have an appointment with the alignment shop for this Friday and will post it on my build thread and the Apex thread.
