05-04-2021, 08:07 AM | #1 |
Which Gen 6 modification provides the most HP/$?
Mods are dealt with everyday here, but I don't recall see a ranking of mods based on cost and HP gained.
I suppose technically you would have to dyno with each mod to say for certain, but we know that mods such as headers would be near the top of the ranking.
'20 ZL1 1LE A10,
05-04-2021, 08:13 AM | #2 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Headers has to be up there on the list. I think the bottleneck in the stock manifolds is the biggest impediment to power. Tune is pretty important in that regard also.
And I guess a 2650R is the ultimate bolt on LOL.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
05-04-2021, 08:21 AM | #3 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
For initial cost...biggest gain for the dollar would be Nitrous. Cost is less than many axle back exhaust systems. Over the long run it could start to even itself out with other mods depending how many bottles you go through.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
05-04-2021, 08:36 AM | #4 |
Drives: A10 ZL1 Join Date: Mar 2018
I gained 150 going to the Maggie 2650
05-04-2021, 08:37 AM | #5 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Nothing is cheap on these cars. For a forced induction vehicle though, typically increasing boost is the most cost effective HP mod which means a pulley swap, however because the stock exhaust manifolds are so restrictive on these cars, headers pretty much become necessary when increasing the boost. Headers are not cheap, nor is installation if you pay someone to do it and then you must also have the PCM tuned which adds more cost. The way these cars are designed, its almost like there are no cheap effective HP mods without some expensive supporting mod to go with it. Even after you go full bolt on, then you have to go into the engine to add a cam for more fuel, even if you didn't want a cam, it becomes a necessity to continue to increase power.
05-04-2021, 08:47 AM | #6 |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
Just day dreaming here..........if you bought a Maggie 2650, paid to have it installed and a custom tune. The sold the stock blower for a reasonable amount.
How much do you think you would have invested?
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
05-04-2021, 08:49 AM | #7 |
E85.
2016 NFG 1SS A8
05-04-2021, 08:52 AM | #8 |
That's a good point, which does require a tune and flex fuel sensor also though. Nonetheless, probably the cheapest bang for the buck mod if you plan to do nothing else and you have E85 readily available and don't mind calculating your blend and the 25-30% reduction in gas mileage.
05-04-2021, 08:52 AM | #9 |
05-04-2021, 09:07 AM | #10 |
Drives: 2017 Camero ZL1 Join Date: Nov 2015
If I were to start with a stock car first mods would be the following:
Rotofab 2" headers/ORX Flex fuel sensor Those three will get you to 625-650 depending on dyno on an E blend. Pulley on stock fuel system limits your ability to run E and these cars see big gains from just E50. Also no heat issues because you're at stock boost levels. Simple and reliable.
2017 ZL1 A10
Dyno/Quarter Mile/Dragy 9.71@141.2 MPH so far. 2007 Z06 H/C/I/E Half Mile - 169 MPH. Sold. |
05-04-2021, 09:37 AM | #11 | |
2016 NFG 1SS A8
05-04-2021, 10:21 AM | #12 |
Prices vary depending on your location. I've done it in my Hellcat for 3 years, it comes up close to the same in my area but costs JUST slightly more to run E85 than 93 but you will also make more trips to the pump which can be a nuisance but was worth it for cheap race gas. I'm all for E85 though. The other part of it is that if you're traveling, you may not be able to find E85, so you'll be down on power using 93.
05-04-2021, 10:43 AM | #13 | |
The 2650 makes a great example: It'll cost say $8100 delivered, and IF you know how to remove the Eaton and install the Maggie, and make NO other mods other than a tune, KaTech says it would likely make around 600-620 wheel, which is 35-55 hp more than mine stock. But, of course, I would and you would make other mods costing $$$$$. Which reminds me, how much more power will a stock LT4 make with only a tune? Perhaps this is the most cost effective mod?
'20 ZL1 1LE A10,
05-04-2021, 10:44 AM | #14 |
I have been running E85 since 2017. The pros outweigh the cons.
I made my statement based on coming from a stock ZL1. You didn't specify what prerequisites the recommendations should be based on. Yes for you to run E85 there is more cost involved. For a stock ZL1 you need a flex sensor and tune to run E70. That will need a 50-70whp gain. The car will also run more consistent all around pull after pull. No other mod will gain that for the cost.
2016 NFG 1SS A8
