02-27-2019, 03:06 PM | #1 |
Drives: 2018 SS 1LE Join Date: Apr 2016
ELSD fluid Part Number
Does someone has the exact part number for the E/Diff module fluid?
Please it's the module fluid and NOT the Differential Fluid. (Sorry if someone posted) just could not find it without getting a straight answer from the other posts I found. |
02-27-2019, 03:30 PM | #2 |
Ok I found the answer..
The ELSD module takes ATF. "and needs a computer/scanner to actuate its pump and valves to purge out air, when it is refilled" Reference: https://www.corvetteforum.com/forums...two-hpdes.html Has anyone serviced this? Do I even need to worry about changing it out after track days? |
02-27-2019, 10:35 PM | #3 |
Drives: A few Join Date: Oct 2017
No.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
02-28-2019, 08:38 AM | #4 |
Drives: 19 SS 1LE Join Date: Nov 2018
02-28-2019, 08:49 AM | #5 | |
The ELSD fluid is not changed unless needed, so it's not a regular maintenance item.
-Dave
03-04-2019, 11:33 AM | #6 |
Drives: 2017 Camaro SS 1LE Join Date: Jun 2018
I've been trying to find the answer to this as well. Seems like everyone is running 75w90 with no issues. Though the 2019 manual for the Corvette says to use DEXRON-VI ATF in eLSD models (Z51, ZR1, Grand Sport & Z06).
https://my.chevrolet.com/content/dam...ers-manual.pdf see page 321
03-05-2019, 02:26 PM | #7 |
Spoke with Valvoline's Tech line (1-800-TeamVAL) clarified that the eLSD takes ATF fluid. Dexron VI ATF or Maxlife ATF.
05-12-2020, 02:02 PM | #8 |
Drives: ZL1 1LE Join Date: Sep 2019
ELSD
It looks like you have the right fluid for the ELSD system. The rear differential fluid is different than the ELSD fluid. Can you tell me how to change the fluid and how often? It would really help. Thanks
05-12-2020, 02:17 PM | #9 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
You do not need to change the fluid in the eLSD module. Diff only.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
05-12-2020, 03:06 PM | #10 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
I was wondering about this too. Thx OP
05-13-2020, 10:15 AM | #11 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
The fluid is cycled thru the module by a pump in the transmission. The ATF in the eDiff is shared with the transmission and is the fluid used to lubricate the transmission (at least in my 1LE SS it is)
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
09-08-2021, 09:43 AM | #12 |
Drives: 2019 ZL-1 Join Date: Feb 2009
So the actual differential fluid is the 80/90 LSD fluid......?
I have to have mine checked....9300 miles
2012 Yukon XL Denali w/ 6.2 AWD |
09-08-2021, 12:36 PM | #13 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I don't think so. The eLSD module fluid is Dexron VI while TR-6060 uses Dexron III. Not the same stuff.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
09-09-2021, 07:42 PM | #14 |
Geoff
there seems to be quite a bit of confusing information being exchanged here
The transmission fluid, either M6 or A10, circulates through the transmission, air to fluid heat exchanger at the front of the car and through a fluid to fluid heat exchanger in the differential housing. If everything is good, the differential fluid and transmission fluids do not mix. There is a 3rd fluid in the ELSD actuator, which also is isolated from the differential fluid. There does not appear to be an interval for periodic maintenance of the ELSD actuator fluid. both the transmission and differential fluids have prescribed maintenance intervals based on vehicle usage, ie track or street hope this helps
