Old 02-17-2022, 09:44 AM   #1
cab33
Drives: Viper
Track fluids
What oils/fluids do you use for the track?
Engine/Trans/Rear end
cab33 is offline   Reply With Quote
Old 02-17-2022, 10:28 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
torco sr1 5w40 engine oil
motul 660 brake fluid
all oem fluids on the rest
Old 02-20-2022, 04:59 PM   #3
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
Mobil 1 15w50, I don't change back to 0w40 because I have a catch can to minimize any potential damage to the cats
OEM fluids for both the trans and differential changed per recommended track hour intervals
Like krops says, a decent DOT 4 fluid
Old 03-29-2022, 02:37 PM   #4
snekk
snekk's Avatar
Drives: 2021 Camaro 1SS 1LE 10AT
Brakes: Castrol SRF Racing (changed every 6-12 months or as needed)
Engine: Mobil1 ESP 0W-40 (changed every 3-4 track days)
Transmission: OEM
eLSD: OEM (changed every 3-4 track days)
2021 Camaro 1SS 1LE 10AT (Track)
  • Wild Cherry Tintcoat
  • Mobil1 ESP 0W-40 w/ ACdelco P64 filter
  • Castrol SRF Brake Fluid
  • Track Alignment (-2 Front, -1.5 Rear, 0.1 Toe)
2019 VW Golf R DSG (Daily/AutoX)
  • EQT Stage 1 ECU/TCU Tune
  • 350whp, 3.6s 0-60
snekk is offline   Reply With Quote
Old 03-29-2022, 06:27 PM   #5
cdrptrks
cdrptrks's Avatar
That's overkill compared to the 24 track hours between changes listed in the manual. It is probably worth paying for a used oil analysis for the diff fluid from Blackstone or another company to determine if you are actually seeing any benefit from changing it that often compared to the manual's recommend interval.
Old 03-30-2022, 09:53 PM   #6
synolimit
Drives: 22 ZL1 1LE A10
redline
synolimit is offline   Reply With Quote
Old 04-06-2022, 11:35 AM   #7
dsheffer46
dsheffer46's Avatar
Drives: 2018 Camaro 2SS 1LE
Engine: 0W40 Mobil 1, before 1st track day of the year and every 3 track days after
Brakes: Motul 660, bleed and add 1 new pint before every track day
Trans: Royal Purple Synchromax, before 1st track day of the year
Diff: OEM ACDelco DEXRON 75W-90, before 1st track day of the year
I run 5-6 track days per season
dsheffer46 is offline   Reply With Quote
Old 04-11-2022, 07:37 PM   #8
synolimit
redline non racing 15w50
OEM A10
redline 75w90 gl5 w/ FM
rbf600
