Old 04-09-2022, 07:39 AM   #1
cjperformance
cjperformance's Avatar
AEM Wideband Capture on Banks Datamonster?
Anyone know if its possible to capture data from an AEM wideband O2 with the OBD II style connector on the banks datamonster? Or is it limited to factory provided pids for logging/display on the Banks?
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 04-09-2022, 02:43 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
I’ve looked into this exact scenario and the quick answer is there seems to be compromises.
I’m going to explain this the way I comprehend it and you come to your own conclusion. Stay with me here.
So Banks offers a B-Bus Expansion module. It appears this module will give you additional sensor inputs. The problem I see is not being able to keep the AEM CAN bus and also having an output signal to the B-Bus expansion module.
This, to me, means you’d have to use an analog WB with the analog adapter from Banks. If that’s true, you’d need the MPVI2 Pro Feature Set for the WB to use AEM’s input analog signal.
I’d think the AEM CAN WB would ideally need an analog output along with the OBDII connector in order to use it with the Banks B-Bus analog input adapter.
Are you looking to be able to log without having your laptop with you?
Old 04-10-2022, 10:46 AM   #3
cjperformance
Thanks for the info. I understood ... and sounds like it's probably more trouble that I'm interested in right at the moment.
As far as logging w/o laptop... Yes and no... I wanted to be able to get *some* kind of wideband logging when I don't have my laptop connected up, but I also know it's not a substitute for logging with HPT for real tuning purposes.
More curiosity than anything.
Old 04-10-2022, 11:32 AM   #4
Trochoidal
After looking at the pinouts again, I believe I stand corrected. I do see unpopulated outputs in the “A” connector. Even if that means the outputs are there, you’d still have to get the B-Bus components and the input adapter.
I agree, it’s more expense and headache but it would be great if the Banks gauge could just pick this up and record that AFR data.
Old 04-28-2022, 06:42 AM   #5
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
FYi the Haltec WB1 or WB2(dual) worked like a champ for me with the Banks just needed to install a 4 pin DTM connector on the end of the banks gauge wire and plug into the WB1 can bus. The aeromotive is prettier to most people but I really like how you can daisy chain the gauges and i like the pillar gauge to do this vs ac pod or ac extension pod.
Old 04-28-2022, 03:10 PM   #6
Trochoidal
If I follow your earlier thread right, wouldn’t you need the Haltech ECM to deliver AFR to the Banks gauge?
https://www.camaro6.com/forums/showthread.php?t=594677
