Stuttering on 8L45
All,
If you have the A8 I4...if it starts stuttering take it to the dealer and/or have it towed....Just destroyed my transmission from driving it a few miles with a stutter. Hopefully will be covered under warranty hoping they can get me pictures of the damage too! Will post if I do.
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
Torque Converter.... did the whole transmission burst to pieces or just stop working?
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Wow I'm surprised it destroyed the trans so quickly like that.
#4 | |
Doesn't register Reverse on HPT RPMs spike and hold when you try to throttle in any gear As am I figured I'd be okay for a few miles of LIGHT driving but guess not lol
#5 | |
603 Camaros
#6 | |
![]() Drives: Camaro like Join Date: Jun 2017
Edit: you mention HPT so I assume your trans was tuned; were you running over 862kpa main pressure? Any changes to the desired slip tables? Last edited by dekes1; 04-30-2019 at 08:38 AM. |
#7 | |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
862kpa would only be about 125 PSI. They are 115psi in stock form. 125PSI would barely give any room for shift speed increases, much less other things. Most guys are staying around 145-150psi on full tunes with no issues when done correctly. I have seen much higher than that even, but time will tell on those.
#8 | |
But in the end, that's what I was hinting at by asking the question on whether his tune was running more than 125psi or not. It would help those of us running higher base pressure to see if there is a reliability concern. |
#9 | |
I'm running 129 psi in the last tune I had at the time of the incident I was doing 37 MPH I don't think pressure wise it's an issue. In my personal opinion(I'm not 100% on these transmissions) with the TCC Locking up it causes the output shaft to lockup and just shred the teeth on it in a violent stutter. So if the car isn't getting any power to the rear wheels with my limited knowledge I'd connect my destruction to the TC locking at times. Which the person doing my tune is apart of Camaro6 if he can shine any more light on it he can only if he wants to make it public.
#10 |
603 Camaros
Did you adjust slip% tables when you tuned your TCM? I'm not certain what my pressure is I'd need to look but i know it's high af according to cooper. I've been driving with the TCM adjustments since last spring so if it was gonna fail I'd think it would have by now or show signs of any issues
#11 | |
#12 |
Hey guys, I just recently started getting the shudder. It’s mostly on the interstate when giving around 10% throttle. What course of action should I take with this? Call my local dealer and schedule an appointment?
HD Cooling and Brakes, Ingen Evo7300, ZZP Throttle Body, and Mishimoto Cat-Back w/ Quad Tips.
#13 |
603 Camaros
Can't hurt. Sounds like low line pressure.
#14 |
Thanks, I’ve been driving exclusively in manual mode ever since I got my cat back, but last week I noticed it when I drove in auto. Is there a fix yet or is it still that triple-flush “band-aid” fix?
